belt size ??
Roert Knight | 03/11/2021 16:08:04 |
2 forum posts | Hi Anyone out there know the dimensions of the belt for a Fobco 7/8 pillar drill? Mine has completely disintegrated, and all I can find on the web are bespoke ones costig £25-35. I think (but may be completely wrong) that they're in the A50-A55 range. Any advice gratefully received. Thanks |
Dave Halford | 03/11/2021 17:23:33 |
2536 forum posts 24 photos | For “A” Belts (1/2” width) subtract two-inches from the outside measurement to select the correct V-belt. For example, if the outer measurement is 48-inches and you subtract two inches then A46 is the size.. Nit so easy when the belt is broken. Edited By Dave Halford on 03/11/2021 17:24:14 |
Ian Parkin | 03/11/2021 17:30:16 |
![]() 1174 forum posts 303 photos | My drill has a A56 fitted |
lee hawkins 1 | 03/11/2021 18:30:51 |
111 forum posts | Hello How about these stores.lathes.co.uk/parts/fobco-7-8-10-8-drill--drive-belt
not done it yet | 03/11/2021 18:38:32 |
7517 forum posts 20 photos | I would measure the pulley diameters and distance between centres (max and min) - then toddle along to my local belt supplier and they would supply a suitable belt. Mine (ABC), would likely provide me with a choice to try, if marginal, and I would return the unused one. |
John Baron | 03/11/2021 19:14:18 |
![]() 520 forum posts 194 photos | Hi Guys, My FOBCO uses an A56 belt ! I got mine from Motorsave, about £7.00p a couple of years ago.
Roert Knight | 03/11/2021 20:36:44 |
2 forum posts | Thank you all so much! I signed up very recently, and learned more in a couple of hours from your replies than after a couple of days googling and ringing round stockists etc,. A fascinating website.
