Unimat 3 Restoration
Graham Meek26/10/2021 16:41:03
714 forum posts
414 photos
I had a visitor to the workshop recently come bearing gifts. In the form of a much used Unimat 3 less original motor. The visitor said he had been given the machine some years ago and only came across it while clearing out the garden shed.
If I could make use of it, then it was mine otherwise it was heading for the skip.
After removing layers of swarf which had congealed with oil and formed a shellac work was started on stripping the machine. While everything was red with rust the bedways were in good order with some slight staining. Clearly the oil on the bedways had done its job in protecting them.
After running a clock over the working surfaces of the Bed there as no more than 0.01 mm maximum wear.
The tailstock working surfaces and the carriage working surfaces were not so good. while there was only about 0.05 mm wear the surface seemed to be filled with abrasive.
Thus yesterday I made a start on machining the faces back to new. The Vee ways can present problems. Thus I opted for using the Dividing Head to guarantee an exact 90 degrees. Which also made machining the flat easy.
Having the Headstock with an undamaged surface it was easy to establish what height the flat was relative to a roller in the Vee way. Machining the two items on a common mandrel ensured that alignment would be maintained.
Before the parts were removed from the mandrel a check was done on the Bed to ensure the mandrel was true or parallel to the bedways.
The last operation on the Headstock was to put Helicoil inserts in the tapped holes which hold the motor mounting plate, apart from painting.
More to follow.
Gray,
Edited By Graham Meek on 26/10/2021 16:44:17
Dave S26/10/2021 19:54:54
433 forum posts
95 photos
Nice job.
Did you take a minimal skim of the headstock and tailstock? (Assume you did)
Graham Meek27/10/2021 10:51:16
714 forum posts
414 photos
Hi Dave,
The Vee's on the tailstock were the worst, but only required 0.08 mm off each face. The Flat required more due to the geometry, but this was in the region of 0.125/0.15 mm. Hard to say exactly as the "touch on" with the cutter would have accounted for something. Even though the cutter still initially left signs of the Felt Tip marker ink.
I have started on the carriage and the new machined faces fit on the bed is as I would expect. The dovetails for the cross-slide will be next. Over 6 mm rollers there is 0.05 mm taper from the unworn part nearest the handle to the end nearest the motor.
In essence it should have a slight cant towards the headstock, so that the machine faces concave. However the machine is also used for milling and this would make the X and Y axis not square to one another. I know I am splitting hairs as the cant will be in the order of 0.01 mm over 100 mm. This is the point where it can be put right, but which is right?, so I am still pondering on this one.
Gray,
Graham Meek27/10/2021 20:43:29
714 forum posts
414 photos
Well after much prevaricating I decided to set the lathe up with a slight cant. It amounted to a quarter of one division on my 0.01 mm clock.
Running a further check over a hardened dowel pin on the un-worn portion of the Master dovetail on the cross-slide showed on error. Thus I concluded I must have hit on the original factory setting, first time round.
While the machine was on the milling table I also cleaned up the front face of handwheel boss. Just in case I need a flat face to reference off at a later date and also to remove the wear. Swarf at sometime had been trapped there and produced anything but a good running surface.
Gray,
Dave S27/10/2021 21:05:57
433 forum posts
95 photos
Looking good. Biggest improvement I made to my Unimat 4 was fitting brass gibs.
Graham Meek28/10/2021 10:58:23
714 forum posts
414 photos
Hi Dave,
I have been pondering over what to use for the new Gib strips. One of the previous owners had overtightened the adjusting screw and split the Moulded Glass reinforced plastic Gibs. My first thoughts were for steel, as the Taper Turning main body is made of steel. Tufnol also came to mind, but given you have had a good experience with Brass I might opt for this material.
Gray,
Kiwi Bloke28/10/2021 11:31:55
912 forum posts
I'm sure brass would be good: it has a fine pedigree in instrument slides. Tufnol came to my mind, too. Perhaps Paxolin would be good, also. I'm a bit suspicious that glass-filled plastics are abrasive, once the surface layer, which seems to contain relatively less glass, starts wearing.
Graham Meek28/10/2021 18:24:44
714 forum posts
414 photos
I have made Brass Gibs today and have so far fitted the cross-slide only. The cross-slide feels silky smooth now. However the taper turning attachment is going to need a bit more work. Holding the slide up to the light the Master dovetail on the toolpost is not matching that on the slideway.
Gray,
Howard Lewis29/10/2021 17:15:49
7227 forum posts
21 photos
You will probably finish up with a machine that is better than new, having painstakingly been fitted, assembled and aligned.
Nice work!
Edited By Howard Lewis on 29/10/2021 17:16:34
Graham Meek29/10/2021 18:20:41
714 forum posts
414 photos
Thanks Howard,
You will probably be right on that score.
Having set the Taper Turning slide up on the mill this morning to skim the Master dovetail. I found whilst clocking the flat of the slideway that the slide had suffered some damage. In that the handle end was dipping away by about 0.15 mm. Where the slideway was bolted to a slave cross-slide in the machine vice there was no deflection.
Using a small screw jack off the bottom face of the machine vice I was able to rectify the error. Just to be on the safe side I machined 0.025 mm off these faces as well.
It is not an easy part to rectify as the feedscrew is fixed in relationship to the dovetails. Luckily my 0.05 mm off the dovetail did not affect this alignment.
The damage was not restricted to the slideway. When I assembled the feedscrew the handwheel end was running out by about 0.15. A few judicial taps with the nylon mallet in the Maximat lathe chuck soon had this part running true.
All is now well with the slideways and I shall be moving on to make a new spindle and tailstock barrel. Apart from both parts being extremely rusty the threads to take the chucks have worn a lot.
Gray,
Edited By Graham Meek on 29/10/2021 18:24:17
Edited By Graham Meek on 29/10/2021 18:24:48
Dave S29/10/2021 20:48:19
433 forum posts
95 photos
Do you mean a taper turning attachment or the top slide add on?
Ive not seen a taper turning attachment (like on a larger lathe) for a Unimat, so that would be interesting.
Graham Meek30/10/2021 10:32:40
714 forum posts
414 photos
Hi Dave,
This is where my memory plays tricks with me. I was convinced Emco called it a Taper Turning attachment, but on checking the Parts List it is indeed referred to as the Top Slide. Which is what I would normally call this part of the lathe. Although it is referred to in other circles as the Compound Slide.
Sorry for building up your hopes on a Taper Turning attachment.
Gray,
JasonB30/10/2021 13:26:13
The price lists and catalogue at the time called it "Top slide for Taper Turning". cost £27.00 in 1984
Graham Meek03/11/2021 13:04:57
714 forum posts
414 photos
On Monday the parts went to the Paint Shop, (aka the Summer House). This being warmer than workshop. I will be first to admit I am no good at paint spraying, but I am pleased with my efforts.unimat 3 back from the paint shop.jpg
I have also taken a photograph of the Cross-slide and Top-slide. The Brass Gib on the cross-slide is easy to spot.
Lastly yesterday was spent on a salvage scheme for the Longitudinal feed nut. The original die-cast nut had worn quite considerably with 0,25 mm backlash. The new Phos Bronze Cylindrical nut has reduced the backlash to 0.05mm. Which is not bad considering it is the original feedscrew.
Tomorrow hopefully I will make a start on the new Spindle and Tailstock Barrel.
Gray,
John Haine03/11/2021 13:15:31
5563 forum posts
322 photos
Are you going to reproduce the original spindle? I made an ER16 spindle for mine using a parallel shank ER16 collet chuck, but it wasn't entirely satisfactory so have reverted to the original, but I would like to have a proper try at a complete spindle with ER16 taper and M22 thread.
Graham Meek03/11/2021 16:28:19
714 forum posts
414 photos
Hi John,
I have acquired quite a bit of "shop soiled" original Emco tooling to go with this lathe, so I will be sticking with the standard spindle. I shall however be making the Spindle and Tailstock barrel from something a little more exotic. Which I hope will be more durable than the standard material.
Gray,
John Haine03/11/2021 17:04:14
5563 forum posts
322 photos
Good plan! The original material does seem a little cheesy. Will you also stick with the horrible circlip arrangement to preload the bearings? On my ER16 spindle I went for an alternative using a
split collar on the left of the spindle which has a radial cut and clamp screw. Then I tensioned the dome washers with a long clamp between the headstock and pulleys (which also had a grub screw to lock on to the spindle), finally fitting the collar snug against the pulley and tightening the clamp.
Graham Meek03/11/2021 17:31:22
714 forum posts
414 photos
Hi John,
I shall be sticking with the circlip arrangement as I have the parts for the Power Feed attachment, but currently no housing. The feed attachment needs the pulley groove in the original spindle. Hopefully Emco Austria will come up with a drawing for this part, so that I can make a new housing. Otherwise I shall be adding a variable DC drive to a home designed housing.
Gray,
John Olsen03/11/2021 20:20:03
1294 forum posts
108 photos
I was hoping that you would put a rack feed on and convert the feed screw to a proper screw cutting setup with change wheels. I could measure up my fine feed if Emco don't come through.
They need a better belt drive too, I mentioned on the current SL thread how I converted mine to toothed belt drive. Poly V would be another good way to go.
JasonB03/11/2021 20:29:35
Gray if you need it I can pull my feed apart and give you sizes.
If you did want to go down the ER spindle route a plain shank/ M14 adaptor would allow the Emco stuff to be used all be it with more overhang. I got one about a year ago and have used it a few times with the 4-jaw when I can't be bothered to change the 5C to 4-jaw on the warco. It's quite nice for small eccentrics etc
