noel shelley | 16/10/2021 19:40:11 |
2308 forum posts 33 photos | Yesterday I was given an almost new SIP 10"bandsaw because the upper wheel had shed it's rubber lining ! A quick look at the assorted inner tubes I have and a pair of scissors cut a 1/2" wide band out of a 10" tube that is a perfect fit. To stop it rippling on the wheel I will bond it with bostic or similar. The reason it was given to me was that the replacement wheels are not available. One could have used 2mm x 12mm rubber strip and scarfed the joint a 1m length would be enough. I might even try something like this on the Dewalt that mice eat the rubber covered wheels on. Ah well. Noel |
larry phelan 1 | 17/10/2021 13:34:33 |
1346 forum posts 15 photos | Feed the mice, it,s cheaper ! |
