Neat idea for a lathe slotter
Bazyle | 24/09/2021 20:09:18 |
![]() 6956 forum posts 229 photos | Although this video is about cutting gears I think the first couple of minutes showing a drill powered slotting attachment is quite interesting. Perhaps overkill unless you are going to cut gears this way or make keyways professionally. Tallado de ENGRANAJE con MORTAJADORA en TORNO METAL #tornometal #engranajes #mortajadora - YouTube https://www.youtube.com/watch?v=CZNadO69Ago It was mentioned on the Drummond Facebook group by, I think, the engineer's son. |
Michael Gilligan | 24/09/2021 20:36:08 |
![]() 23121 forum posts 1360 photos | Yeis indeed : That’s neat An induction motor might be nicer though. MichaelG. Edited By Michael Gilligan on 24/09/2021 20:38:11 |
noel shelley | 24/09/2021 21:01:50 |
2308 forum posts 33 photos | VERY neat ! there are many uses for a small worm drive box. It would be Good way to use a small 3ph motor and a VFD. Several holes in the output wheel/plate at various radiuses to give a choice of stroke. Noel |
Clive Foster | 24/09/2021 22:06:30 |
3630 forum posts 128 photos | More details of the device here **LINK** https://www.youtube.com/watch?v=nBPIRD0ih2k . Several others featuring it too I think. Especially for Michael and noel a couple of links to two of several YouTube videos of an induction motor powered variant Here **LINK** https://www.youtube.com/watch?v=drtQsbEWVUI and here **LINK** https://www.youtube.com/watch?v=9kZhpmJGxpU. The induction motor version has vertical adjustment on the slotter tool carrier. Although it obviously permits vertical adjustment I'm unconvinced that there are any advantages to offset the inherent loss of rigidity over a solid carrier. Mounting on the cross slide and working sideways gives at least equal adjustability. Clive Edited By Clive Foster on 24/09/2021 22:07:37 Edited By Clive Foster on 24/09/2021 22:08:06 |
Michael Gilligan | 24/09/2021 22:33:22 |
![]() 23121 forum posts 1360 photos | Thanks, Clive MichaelG. |
Bob Stevenson | 25/09/2021 10:21:18 |
579 forum posts 7 photos | I did'nt understand a single word but I instantly liked that bloke!....a real enthusiast and engineer...I liked the way he spoke, the way he used his hands and also his simple but businesslike garage..... I would be honoured to meet him!
....Actually you can 'plain' clock pinions by hand using your top slide and you don't need any motor. |
pgk pgk | 25/09/2021 10:48:07 |
2661 forum posts 294 photos | I'd have liked to have seen how he ground the tool profile. pgk |
ega | 25/09/2021 14:10:32 |
2805 forum posts 219 photos | I enjoyed the OP's linked video even though it helped only slightly to turn on translated subtitles. |
noel shelley | 25/09/2021 14:25:31 |
2308 forum posts 33 photos | Thanks Clive ! PGK grinding the tools is shown on one of the Tube programs linked above. On the basis of the time of year and how much I need a slotter now The small worm drive box I have is more likely to be used to make a kindleing cutter, the 12ton hydraulic splitter is a bit slow and it would be criminal to use the elliot M10 for this purpose, Cheers, Noel. |
Michael Gilligan | 25/09/2021 15:21:45 |
![]() 23121 forum posts 1360 photos | Posted by Bob Stevenson on 25/09/2021 10:21:18:
. ....Actually you can 'plain' clock pinions by hand using your top slide and you don't need any motor. . Quite so, Bob …. But, depending, of course, on size: You may be subjecting the slide and its feed-screw to excessive loads. The stand-alone ram seems a much better tool for planing [at least to me] MichaelG. |
