Ian Parkin | 18/09/2021 11:42:14 |
![]() 1174 forum posts 303 photos | Here’s a angle grinder nut disassembled for your perusal i have quite a few of these as i never seem to be able to find a peg spanner…these nuts work great …tighten as tight as you wish by hand use the tool for ages then when you want to change the disc the nut comes loose easily by hand Edited By Ian Parkin on 18/09/2021 11:42:57 |
not done it yet | 18/09/2021 13:56:55 |
7517 forum posts 20 photos | Ian, Not much to them, then!🙂 I like mine, too. Thanks for showing the complexity of the things. I lose the narrow spanners for holding the shaft, as well as the peg spanners. I like the newer ones with spindle locks… |
John Reese | 18/09/2021 22:06:20 |
![]() 1071 forum posts | On a DeWalt grinder I purchased the holes in the nut were hexagonal. If I lost the spanner I could use an Allen wrench. |
old mart | 20/09/2021 21:09:42 |
4655 forum posts 304 photos | That looks like a Bosch SDS special nut that doesn't need a spanner. Common nuts on angle grinders have two holes for a peg spanner. |
ega | 21/09/2021 13:45:52 |
2805 forum posts 219 photos | My Bosch angle grinders have been retro-fitted with FIXTEC brand tool-free nuts which may be similar to the OP's; they do, however, have a flip-up half-moon feature which I don't see in the photo. Long term users of the Tormek wet grinder will know that their original nuts had to be hammered tight but later models feature an ingenious two-start left hand threaded nut which is easily removed by hand. |
