Brian John | 03/09/2021 07:32:39 |
1487 forum posts 582 photos | I have some 2 year old silver solder which has been hanging on the wall inside the house. It is good quality silver solder with cadmium which I use for soldering copper boilers. It has lost its bright and shiny new look ; it is a bit ''tarnished'' for want of a better word. Should it be cleaned before use by using steel wool or something similar ? NOTE : I always make sure the copper surfaces to be soldered are clean and bright and I use plenty of flux. |
Brian H | 03/09/2021 08:54:01 |
![]() 2312 forum posts 112 photos | Hello Brian (what a good name!), personally, I would clean off the tarnish before use but not with wire wool as it can leave particles of steel embedded in the silver solder. I just use some fine emery paper or cloth and wrap it around the silver solder sticks and pull the stick through a couple of times. Brian |
Baz | 03/09/2021 08:54:17 |
1033 forum posts 2 photos | I have some very old easyflo that is tarnished, it dates back to the 1980s, I give it a pull through a piece of scotchbrite before I use it, probably unnecessary as the flux would remove the oxides but it makes me feel happier. |
Keith Hale | 03/09/2021 09:20:10 |
![]() 334 forum posts 1 photos | Hi Brian, If it makes you feel better, then clean it, but it's not really necessary. The tarnish is only a film of oxide that the flux will remove. When doing a brazing demo, I might have cleaned the rod purely for a esthetic reasons. I would use a piece of newspaper. If the silver solder contained more than than 40% silver I would use a broadsheet, if it was less, I found a tabloid satisfactory! Regards Keith
Brian John | 03/09/2021 14:09:43 |
1487 forum posts 582 photos | Okay, thanks for that. It is probably not necessary but I will give it a quick pull through some emery paper anyway. |
