Manufacturers size designations.
Bob Mc | 23/08/2021 08:08:04 |
231 forum posts 50 photos | Hi All... am in the process of making an r/c boat, I need to find out which motor to use, I have already used a '400' type motor but have no idea what this means ... I will require a larger motor for the next build so need to know volts/amps/rpm/mechanical size etc.... is there a chart for all this? will be grateful for any information....Bob. Edited By Bob Mc on 23/08/2021 08:09:09 |
mick H | 23/08/2021 08:40:49 |
795 forum posts 34 photos | A lot of the information that you require can be found on The Component Shop website catalogue. Mick |
Circlip | 23/08/2021 08:49:53 |
1723 forum posts | Try this site Bob, :- Model Boat Mayhem - Index Regards Ian. |
Jouke van der Veen | 23/08/2021 09:15:41 |
203 forum posts 19 photos | Some years ago I completed a 1 meter long tugboat, originally built by my son 25 years ago. Searching for a motor I found information on the internet to use a 12V brushed motor from a car interior blower. Cheap and with sufficient power to give the boat the speed belonging to its scale.
Ron Laden | 23/08/2021 10:14:44 |
![]() 2320 forum posts 452 photos | Have a look at MFA COMO DRILLS they have a large selection of motors and motors with gearboxes, they also give the full spec for all their types. |
Joseph Noci 1 | 23/08/2021 11:04:24 |
1323 forum posts 1431 photos | Posted by Bob Mc on 23/08/2021 08:08:04:
Hi All... am in the process of making an r/c boat, I need to find out which motor to use, I have already used a '400' type motor but have no idea what this means ... I will require a larger motor for the next build so need to know volts/amps/rpm/mechanical size etc.... is there a chart for all this? will be grateful for any information....Bob. Edited By Bob Mc on 23/08/2021 08:09:09 Hi Bob. The term '400 type motor' ( called Speed 400 back then..) dates back a while, and very loosely referred to a motor around near 38mm long, a 500 motor was near 55 or 56mm long, etc. The old 400 DC motors were around 100watts max or so, 10 to 12 amps typically. If I recall, the Speed 400 was around 30mm in diameter. Are you set on a DC motor? Do you already have the DC PWM RC speed controller? If so that would set some limits on the motor amps/volts choice I guess. If you are not set on DC, the RC brushless DC motors are a good option. Much more efficient and more power in smaller packages compared to the somewhat dated construction of the cheap Speed series DC motors. A visit to your local RC hobby shop will deliver.. Eg:
Joe |
Bob Mc | 27/08/2021 15:28:49 |
231 forum posts 50 photos | Sorry to reply so late ... was away for a few days and didn't see the responses....thanks to all who replied to my question, these have been most helpful... rgds..Bob. |
