sparky mike | 20/08/2021 11:55:19 |
259 forum posts 77 photos | Hi I have a Verdict dial indicator and I believe the hair sprig has broken or become detatched. Anyone had experience taking these apart ? Where can you get new hairsprings from ? Mike. |
Robert Butler | 20/08/2021 12:02:03 |
511 forum posts 6 photos | Google Verdict Dial Test Indicator Spare Parts. Robert Butler |
peak4 | 20/08/2021 12:56:09 |
![]() 2207 forum posts 210 photos | The ones I have, you can take a side plate off, which exposes the workings. Bill |
Clive Foster | 20/08/2021 13:01:58 |
3630 forum posts 128 photos | MJ Allen, who currently own verdict, offer a repair service for most reasonably recent models. My experience a fair few years ago was that repair costs were around half the cost of a new equivalent. https://mjallen.co.uk/products-and-services/metrology Does depend on whether they still make or hold parts. I know they can no longer fix the cylindrical body type. When I asked about getting my rather sticky "not so E-Bay bargain" one repaired I had the distinct impression that Verdict were unhappy with the general performance and durability of that version! Not only was repair not possible they also suggested that, if I had any others of that style, I be prepared for their demise. Apparently the more compact mechanics had unsolvable durability issues. Clive |
sparky mike | 20/08/2021 15:13:05 |
259 forum posts 77 photos | t the moment there does not seem to be any way to get into the workings of the dial. I have removed side plate with its minute screw, but all looks fine in there. Re. the early type, my father used to make parts for these in a sub contract role at Astralux in Brightlingsea Essex. Somewhere I have the blueprint drawing of one . I will have to dig it out and post it on here. Mike. |
old mart | 20/08/2021 20:45:31 |
4655 forum posts 304 photos | Replacing the hairspring would be quite difficult for a beginner. The exact hairspring would not be vital as it only eliminates backlash. |
sparky mike | 21/08/2021 09:15:37 |
259 forum posts 77 photos | Based on the well worn theory, some human put it together in the first place (not always correct in these automated days !! ),it should be possible to take it to pieces. It is composed of two units, the base unit, which presents no problems and the dial /stem unit, which looks like it is pressed into the base/stem. I wonder if the only way in is to remove glass /needle and dial to get to the hair spring. I did wonder if the ball end was too tight but a drop of oil proved that not the case. Mike.
sparky mike | 21/08/2021 09:57:37 |
259 forum posts 77 photos | Now this has got me stumped. Found out this morning that the needle retracts fine when verdict is on its side (either side) or upside down ,but not when dial is at the top. ??? Mike. |
roy entwistle | 21/08/2021 11:05:47 |
1716 forum posts | Sounds like it needs cleaning and lubricating Roy |
peak4 | 21/08/2021 12:04:22 |
![]() 2207 forum posts 210 photos | I had one the same. My guess is that it had been banged or dropped allowing the dial end of the operating lever to jump one or two steps. Bill |
sparky mike | 21/08/2021 12:26:45 |
259 forum posts 77 photos | Hi Bill, exactly what I have found !! The pointer looks like it is slightly off set and I would think it should be straight. Howvever, I don't intend to straighten it as it may well then break.. I found that the weight of the beam when the indicator was upright, was too great for the return/hair spring and after a bit of trial and error, putting the end of the beam in different positions on the worm , it now works well. I replaced the beam spring by looping a piece of cottom thread on it and then lifting it just enough to fit it into the hole on the beam. I had removed the complete beam which in my case needed a 4mm spanner on the lock nut. The beam would not have to be removed if you wanted to just move beam to new position on the worm, but the screw would need to be loosened a few turns. You can only access the screw by moving the spring clip to one side ,that holds the ball of the pointer in place. It only cost me £10.00 at a boot sale at which I also bought a set of USA micrometers (Tool company Auburn) for similar price, and also includes in the case various adaptors. There is one short brass adaptor but this may have been home made or may have nothing to do with it. Thanks for all replies. Mike.
