Cut it yourself!
David Colwill | 19/08/2021 14:02:24 |
782 forum posts 40 photos | The other day I needed to do a job that would involve a 5C collet with a stop. Sadly my 5/16 collet did not have the internal thread for the stop to screw in. I do own the type that expands into a plain bore but don't like it. I thought that I would have a go at threading the collet (a genuine Hardinge) but didn't think I would stand much chance. I used a generic 60 degree 16ER type insert. It was in the end very easy. David. |
Baz | 19/08/2021 14:33:58 |
1033 forum posts 2 photos | Strange that some collets are internally threaded and some not, when I was working we had dozens of genuine Hardinge 5C collets, some were threaded, I assume there was an option when ordering them, threaded or not. I also don’t like the expanding type, they tend to slip, the screw in ones however are excellent, especially as extension tubes are available so long jobs can be accommodated. |
Ian P | 19/08/2021 15:38:00 |
![]() 2747 forum posts 123 photos | David, how did you hold the collet? Ian P |
David Colwill | 19/08/2021 17:17:04 |
782 forum posts 40 photos | Posted by Ian P on 19/08/2021 15:38:00:
David, how did you hold the collet? The collet in question was 24mm. I turned a piece of bar to 24mm and then tightened a 5C collet block on to it. It looked rather Heath Robinson but worked very well. David. |
