Tailstock DRO
duncan webster14/08/2021 22:19:35
5307 forum posts
83 photos
back in the March 2021 edition of ME I described how to make a rotary encoder based DRO for the tailstock, and several people asked for the code. One at least has got it working, but not without issues. Following advice from Silly Old Duffer, there are 2 issues
Firstly I forgot to mention in the article that you have to download the TM1638plus library. Instructions on how to do this are given in lib
They have changed this library between my installing it and now, so my code needs changing a bit. Right at the top are 3 lines which say
#include <TM1638plus.h>
#include <TM1638plus_font.h>
delete the second 2 lines so it just says
This may still not be enough, it appears there are some old stock Arduinos out there which the modern compiler will not deal with. If you get a message like
avrdude: stk500_recv(): programmer is not responding
then that is your problem. To cure it go to Tools->board and select Arduino nano. Then go to tools->processor and select ATmega328P(OldBootloader)
If you still have issues let me know and I'll try to sort it.
Mine worked pretty much out of the box
Michael Gilligan14/08/2021 22:36:00
23121 forum posts
1360 photos
Thanks for the update, Duncan
… this device is somewhere on the Round Tuit list
duncan webster19/08/2021 13:02:36
5307 forum posts
83 photos
I've found another Bill Gates inspired issue, at least I think it's him. I tried to upload a sketch to a fairly new nano (bought within the last couple of years) and my new computer couldn't find which port it was plugged into. Tried with a UNO same, then tried both on my laptop and both worked. It appears that the USB chip is 'obsolete' and Mr Gates has decided we shouldn't be using it, and so W10 cannot now find the drivers. I sorted this after much googling by downloading and installing CH341SER.EXE
This sorted mine out, but wasted a couple of hours
peter ravenscroft19/08/2021 18:23:14
100 forum posts
hi duncan
i built mine as described and it works very well don't know how i managed before
regards
peter
DEREK SPEDDING 122/08/2021 08:08:00
8 forum posts
Hi Duncan.
Please could you point me in the direction of the code. I intend fitting the system to my Boxford.
Derek
duncan webster04/09/2021 12:10:36
5307 forum posts
83 photos
I Derek,
Sorry I missed this, but I answered your pm. You need to send me your email via a pm
