steamdave | 30/06/2021 12:34:27 |
526 forum posts 45 photos | Is it possible to organise Excel into ascending or descending order across all columns? I particularly would like to reorganise the Model Engineer index Excel spreadsheet to show contributors in alphabetical order with their contributions. This would make it easier to search for particular articles. I can sort and filter Authors in alphabetical order but the remaining columns are not sorted using the Sort & Filter button. Dave |
DC31k | 30/06/2021 12:57:07 |
1186 forum posts 11 photos | https://support.microsoft.com/en-us/office/sort-data-in-a-table-77b781bf-5074-41b0-897a-dc37d4515f27 Your question starts at sub-section number 3. |
Bizibilder | 30/06/2021 12:57:52 |
![]() 173 forum posts 8 photos | Highlight the entire sheet and then use custom sort to sort on the column you require - the whole sheet will be sorted. |
Calum Galleitch | 30/06/2021 13:07:55 |
![]() 195 forum posts 65 photos | Dave, if you highlight the entire table before turning on the sort/filter tool (or off and on again), it should keep all the rows in order. Let me know if you're struggling and I'll see if I can sort it out for you. |
Paul Lousick | 30/06/2021 13:12:01 |
2276 forum posts 801 photos | Make a copy and use it for sorting columns. Unlike a database (MS Access, etc) the data in the columns for each record is not linked together and easy to mix them up and ruin the file. Edited By Paul Lousick on 30/06/2021 13:13:18 |
steamdave | 30/06/2021 16:32:00 |
526 forum posts 45 photos | Thanks gents for your help. All sorted now. Dave |
John Haine | 30/06/2021 16:58:54 |
5563 forum posts 322 photos | You have probably seen this now, but if, having sorted, you click on the little down arrow next to the column head it gives you a list of all the contents in that column with a tick box. If you untick them all by clicking on the "select all" box then click the (say author) you want it will show you just the relevant entries. |
