smokebox
MrT42 | 28/06/2021 13:12:55 |
7 forum posts | Hi Ive just started to build a 3inch Fowler traction engine and have hit my first hurdle. I cant source a piece of tube suitable for the smoke box. The drawing specifies 190mm od 5mm wall thickness. The smokebox ring casting is 185mm od (un-machined) , so id of tube needs to be slightly less. I need 200mm length. I dont really want to get it rolled and welded but not really sure what else to do. Does anyone have any suggestions please. Thanks Jonathan |
JasonB | 28/06/2021 13:25:35 |
![]() 25215 forum posts 3105 photos 1 articles | Rolling and welding is the usual way to go, same as the wheel rims, someone like Ashby will do them and are traction engine friendly. Other option is a thick wall tube and bore it out which can sometimes be taken advantage of by doing away with the front door ring and and adaptor ring onto the boiler. M-Machine have 193.7 x 12.5 wall. 193.7 x 6 is a structural size so you may be able to get an offcut of that, and adjust other parts to suit Edited By JasonB on 28/06/2021 13:28:51 |
Andrew Johnston | 28/06/2021 14:26:58 |
![]() 7061 forum posts 719 photos | Machining a thin walled cylinder is a tricky but avoidable problem. I bought my smokebox rolled and tack welded. I completed the seam weld, welded in a rolled length of BMS and machined the smokebox door ring to fit. I then drilled all the circumferential holes: The ring was bolted to the smokebox and used to clamp the smokebox to the small faceplate so I could machine out the rolled BMS to the average diameter of the boiler: Andrew |
Former Member | 29/06/2021 20:51:43 |
1085 forum posts | [This posting has been removed] |
Paul Kemp | 30/06/2021 01:25:27 |
798 forum posts 27 photos | I would say about the only useful information from a copper boiler drawing if you want to make a steel one is the overall sizes, barrel diameter, overall length, width and height. 2 completely different materials with completely different properties. Paul. |
JasonB | 30/06/2021 07:03:33 |
![]() 25215 forum posts 3105 photos 1 articles | Even diameter would only be a guide as you would have to go with available tube sizes. Steel also has knock on effect of different stay layout affecting horn plate drilling. Different dia & possibly external thickening pads affecting smokebox ID, cylinder and weigh bracket undersides and a whole host of other small items. |
