Does it have any value? Or best way to dispose of it, if not worth anything.
not done it yet | 24/05/2021 19:37:40 |
7517 forum posts 20 photos | As the title really. I have been asked by a third party if there is any demand for 20% copper sulphate solution (in dilute sulphuric acid) for electro forming/plating. Don’t know the location as yet, but it might well help out someone doing this sort of thing. |
Oily Rag | 24/05/2021 21:14:42 |
![]() 550 forum posts 190 photos | I use it as a marking out medium. Paint it on and magically watch steel turn to copper! a scribed line shows up really well and is not washed off by oil/coolant. I still use marking blue for aluminium though. Got about half a pint left from an original two pint stock about 20 years ago. Probably have to be transported by licenced courier though as it is dangerous for the 'elfins. Martin |
Nigel Graham 2 | 24/05/2021 22:56:49 |
3293 forum posts 112 photos | Hopefully someone here can take it away to use. Plate the copper out and you have a pickling fluid. If he ends up having to dispose ot it, one way might be to plate the worst of the copper out, then neutralise the acid with crushed chalk or limestone (same stuff). The result is calcium sulphate - aka gypsum, which occurs naturally as a rock. Rinse or weather the remnant acid and copper away, and then if left to me I'd dig it into the garden or put it in the local council rubble skip (it's the raw material for plaster). |
Bazyle | 25/05/2021 00:08:53 |
![]() 6956 forum posts 229 photos | Basis of Bordeau mixture for gardeners to spray on roses....... I've recently heard somewhere that the clean air is making it hard to grow roses in London now. Edited By Bazyle on 25/05/2021 00:10:03 |
pgk pgk | 25/05/2021 07:06:09 |
2661 forum posts 294 photos | Copper sulphate solution will be acidic anyway. Is the original solution here actually in dilute sulphuric acid or just in water? You can buy copper sulphate crystals - ebay for instance - and make your own solution. Indeed since the bordeaux soln mentioned isn't available UK to my knowledge I make my own (with calcium oxide) just for spraying my citrus trees before packing them away in the greenhouse for winter. Humidity Wales leads to Botrytis here. pgk |
Neil Wyatt | 25/05/2021 12:18:31 |
![]() 19226 forum posts 749 photos 86 articles | If it's a waste product from commercial plating, and they are trying to avoid the costs of proper disposal it's a bit concerning. Hopefully, the alternative isn't it going down a drain. If its someone who disposes of it properly but thinks they may be able to make a few quid on the side, less so. Neil |
