The home engineer | 10/05/2021 14:11:49 |
5 forum posts 3 photos | Hi All I would be very grateful for someone could help identify the castings in the photos. I have been clearing a friends workshop and came across these casting in a box and would really like to know what they are for. I thank all in advance for taking a look Andy
Nigel Graham 2 | 10/05/2021 14:58:28 |
3293 forum posts 112 photos | A rule or familiar object for scale would help, if you can supply - of at least give us the basic measurements. The larger casting appears to include bearing journals and suggests the headstock for a small lathe. It looks as if the owner had just started to machine it. The smaller one could be almost anything though a pipe-fitting manifold comes to mind. Any clues from your friend's main engineering line? Any drawings about? (He may have kept them in the house.) |
not done it yet | 10/05/2021 17:34:28 |
7517 forum posts 20 photos | Tool & cutter grinder kit? |
bernard towers | 10/05/2021 18:26:58 |
1221 forum posts 161 photos | Might pay you to ask Kirk from Hemingway he has lots of info on castings |
The home engineer | 14/05/2021 12:44:45 |
5 forum posts 3 photos | "A rule or familiar object for scale would help, if you can supply - of at least give us the basic measurements." Hi The large casting basic dimensions are 3" in all directions, large boss 1" diameter with 7/8" gap one is 7/8" long the other1"1/4. The gap is 1"5/8 between the lugs. The small casting is 5/8" diameter 2" long with 4 off 3/8" bosses. My friend was a keen clock man but also made many tools for the Myford ML7 lathe. Thank you all again for any further help Andy Edited By The home engineer on 14/05/2021 12:46:06 |
Bazyle | 14/05/2021 18:14:03 |
![]() 6956 forum posts 229 photos | They might have nothing to do with model making activities. The larger casting could easily be part of a loom or other industrial machine that was picked up by some factory or foundry hand because it looked like it might be made into something at home. |
