Stuart Victoria Query
Clive Brown 118/04/2021 16:25:12
1050 forum posts
56 photos
I'm just starting to build a Stuart Victoria engine.On examining the drawngs, I'm slightly surprised that the crankshaft is positioned 1/4" above the cylinder centre-line. Does this height difference have a noticeable effect on the running of the engine, eg a slightly uneven exhaust beat. Do any other Stuart horizontals have this feature? Just curious.
JasonB18/04/2021 17:08:00
Should not be. The ctr height of the hole in the main bearings is 5/8" from bottom. (wrong on the 1993 drawings) The ctr line of the holes in the cylinder support brackets are 5/8" from bottom and adding up the various bits of the cross head guide put the cross head pin 5/8 up.
Horizontal green ctr line runs straight through all three points
You may want to have a look at this thread where depending on what drawings and or book you are working from there are errors, I'll going to post a set of corrected drawings soon if you can wait.
Edited By JasonB on 18/04/2021 17:16:14
Edited By JasonB on 18/04/2021 17:21:42
Clive Brown 118/04/2021 18:35:45
1050 forum posts
56 photos
Thanks Jason. I have the 1993 drawings. I had read the linked thread where discrepancies were pointed out but these seemed to relate to the longitudinal positions of the cylinder, slide-bars etc. I've fabricated the bed and was intending to measure up as the job progressed and make items such as the con-rod to suit. However, my drawing clearly dimensions the main bearings at 7/8" above the bed compared with the cylinder at 5/8". Scaling off the drawings also confirms these figures, the draughtsperson must have been having a bad day. I'll make my bearings 5/8" as you advise.
I await your corrected drawings with interest.
PS.I wonder how many Victorias have been made with the height difference?
Edited By Clive Brown 1 on 18/04/2021 18:44:54
Steve Withnell19/04/2021 08:38:57
858 forum posts
215 photos
Mine certainly has! It's not getting rebuilt now...
Victoria
You can hear the big end knocking, that I will fix one day Usual shortage of 'roundtuits'.
Steve
duncan webster19/04/2021 19:31:41
5307 forum posts
83 photos
Lots of GWR locos had the cylinder centre line above the axle centre line, didn't seem to bother them over much. Makes valve timing a bit different, but Steve's video shows it doesn't matter much
JasonB19/04/2021 19:35:39
I think the problem was a bit of early cut & paste when the '93 drawings were done and a few bits from the beam got copied rather than having the subtle alterations done for the Vic.
I've a set of castings for a smaller ball hopper engine that like the full size has an offset crankshaft.
