DeskCNC resurrection - USB to serial adapter
Tony Jeffree09/04/2021 14:27:13
569 forum posts
20 photos
I converted my Taig CNC mill some years ago to make use of DeskCNC as the controller software/hardware (writeups were in MEW at the time). The mill has been gathering dust since we moved to Scotland in 2014 and I have only recently been resurrecting the PC side - the original laptop that I used had a serial (COM) port, which is long gone from modern spec PCs, so a major hurdle was to find a suitable USB-to-serial adapter that would do the job. I had 2 of these lying around that I spent much time & effort on, unsuccessfully - mostly due to hardware in the adapters that was too old to have any drivers that would run on Windows 10. So, after much frustrating effort, including managing to get one of the adapters to sort-of work with an old driver, I bit the bullet and bought a new adapter, one of these:
<USB adapter>
Which seems to work nicely with the in-built driver options that Win10 provides. I thought it would be worth mentioning in case others have come across a similar problem.
Now to see if I can remember how to run the mill and cut a few parts...
Emgee09/04/2021 15:17:26
2610 forum posts
312 photos
Thanks for the advice the adapter works OK, this topic often arises on the Emco and Denford forums when using old machines that need the Serial link for communications.
Emgee
Tony Jeffree10/04/2021 11:02:59
569 forum posts
20 photos
yes
