David Noble | 07/04/2021 14:34:38 |
![]() 402 forum posts 37 photos | As all my gear cutting has been in clockmaking, I have been using cycloidal form gear teeth. I have one involute gear to make it is Mod 1 & 63 teeth. I would be grateful to know the full depth I ought to cut it. Many Thanks, David |
Howard Lewis | 07/04/2021 15:17:20 |
7227 forum posts 21 photos | If you use an Involute gear cutter, it is likely to be marked with the df number, which is the depth of cut. If you intend to cut any more gears, Ivan Law's book on "Gears and Gear Cutting", No.17 in the Workshop Practice Series will be a good investment and a very useful guide and reference. Howard |
DC31k | 07/04/2021 15:26:28 |
1186 forum posts 11 photos | Posted by Howard Lewis on 07/04/2021 15:17:20:
More usually referred to as d + f . If you search for 'd + f gear' or 'whole depth of gear tooth', there is a lot of material available. For metric gears, this one is good: https://khkgears.net/new/gear_knowledge/abcs_of_gears-b/basic_gear_terminology_calculation.html For imperial gears (not your current challenge), this one is good: https://www.bostongear.com/-/media/Files/Literature/Brand/boston-gear/catalogs/p-1930-bg-sections/p-1930-bg_engineering-info-spur-gears.ashx |
John Hinkley | 07/04/2021 15:57:58 |
![]() 1545 forum posts 484 photos | David, To answer your question directly, I used my go to gear generator software. It gave the following result for the quoted gear: In case it's not too easy to see from the above screenshot, the depth of cut works out as 65.0 - 60.5mm = 4.5mm. Or if you prefer, 0.177in. John
David Noble | 07/04/2021 17:13:40 |
![]() 402 forum posts 37 photos | Many thanks everyone. It's a change gear for my metric lathe so I can cut imperial threads. David |
Pete Rimmer | 07/04/2021 17:18:02 |
1486 forum posts 105 photos | Posted by John Hinkley on 07/04/2021 15:57:58:
John, it's actually half of that. Regards Pete |
David Noble | 07/04/2021 17:55:11 |
![]() 402 forum posts 37 photos | Posted by Pete Rimmer on 07/04/2021 17:18:02:
John, it's actually half of that. Regards Pete Thanks Pete, I had already 'read between the lines' David |
John Hinkley | 07/04/2021 19:06:14 |
![]() 1545 forum posts 484 photos | Posted by Pete Rimmer on 07/04/2021 17:18:02:
John, it's actually half of that. Regards Pete Well spotted, Pete. Should have been obvious, really. I thouht it was a bit deep at the time, but failed to apply what little common sense I have left! John
not done it yet | 07/04/2021 19:12:18 |
7517 forum posts 20 photos | Good program. I would have expected the pressure angle to be given as 20 degrees, not 14.5. |
Pete Rimmer | 07/04/2021 21:25:36 |
1486 forum posts 105 photos | Posted by not done it yet on 07/04/2021 19:12:18:
Good program. I would have expected the pressure angle to be given as 20 degrees, not 14.5. You can specify but for the purpose it wouldn't matter, the whole depth is the same for both. |
Howard Lewis | 08/04/2021 19:56:38 |
7227 forum posts 21 photos | I would have expected module gears to be 20 degrees pressure angle. You are obviously thinking of a 63T gear. They are available for mini lathes.(Arc Euro sell aluminium ones ) Using a 63T gear in the train will not be an absolutely precise (You need a 127T for that, but a 1 Mod gear will be big - 129 mm diameter! ) For most purposes, the errors with a 63T gear will be tolerable. Howard |
