Rocketronics Electronic Lead Screw
ChrisB05/04/2021 08:01:58
671 forum posts
212 photos
Been trying to find a way round the fiddly process of changing gears back and forth for threading and turning for quite a while. I had made up my mind I wanted an ELS for my lathe and Clough42 and his very well explained tutorial on youtube seemed the way to go. I also read through the ELS project thread on the forum which was very helpful.
Then I came across this german site which have a complete kit for different sized lathes, and after reading through their system's functions it would seem it's one step short of turning your lathe into a CNC.
Apart from the thread cutting functions, it will do tapers (that is I can do away with the compound and replace with a solid tool post), ball turning, DRO function and more. It is expensive tho at around 1K, but with the tools it replaces would probably break even... There are also less expensive less fancy versions as well. I'm tempted!
What are your thoughts, anyone came across it before?
hubertus fischer05/04/2021 09:04:50
7 forum posts
fitted a rocketronics els- to my emco compact 8 and i am very happy with it.
Bazyle05/04/2021 09:17:32
6956 forum posts
229 photos
You haven't said which lathe you have but below £3k adding an extra £1k to your budget will get you into the realms of a very good lathe for amateur use. This device, being specialised electronics will become virtually worthless the moment it is bought, and uness from a major supplier has no garuantee of long term support.
The link you have given seems to be a £500 CNC type controller.??? I haven't tried translating it.
ChrisB05/04/2021 09:39:33
671 forum posts
212 photos
My lathe is a WM280v. I think the product is aimed at hobby machines which might be bigger or smaller than mine without a gearbox.
Yes the link is for the controller correct, but they have kits with motors to drive both axes **LINK**
The website is both in english and german (it's translated by default on my pc tho) and I do believe they have support as I have asked them some questions, particularly if the system is adaptable to an imperial leadscrew lathe, which I'm told it is. He also said currently the system works in metric but they are working to include inches, so I guess it is still in development,
John Haine05/04/2021 09:54:52
5563 forum posts
322 photos
Posted by ChrisB on 05/04/2021 08:01:58:
Well to all intents and purposes it is full CNC with a wide range of internal wizards. It isn't clear if you can run g code from external CAD/CAM which would be a serious limitation IMHO given the price. So ~£500 for the control box, then you need motors and drivers and PSU. John Stevenson looked at some of this type of packaged controllers - have a look at this thread - and was very impressed.
One thing this unit doesn't seem to support is probing to support tool setting which is a serious shortcoming in my view.
John P05/04/2021 10:03:40
451 forum posts
268 photos
Hi Chris
Looked at the linked site seems to be a complete package to do what you wish.
I suppose the real problems is fitting it to the Warco WM 280 lathe ,the Emco
from the 2nd poster Hubertus Fischer is much the
same as a changwheel Myford 7 lathe where direct access to the leadscrew is
possible ,with the Warco the leadscrew is connected though the gearbox.
I fitted a cnc system to my GH 1000 warco lathe and faced similar problems
it was featured as an article in MEW 207 to 212 i got around the leadscrew/gearbox
by fitting a removable second leadscrew ,the whole conversion only needed the
fitting of about 5 additional screw holes and still retained the full manual machine
operation.
There was some criticism about the article in this thread
https://www.model-engineer.co.uk/forums/postings.asp?th=88623
mostly by people who had not bothered to read the article properly ,one even
claimed that i had some complicated , " the gears, helical planetary ones" ,
of which there were none.
It would be worth looking at the mechanical connections needed before
committing yourself to proceeding with this type of conversion.
JasonB05/04/2021 10:17:15
I would have thought leaving the gearbox in "A" which is a direct 1:1 drive would not be a problem apart from any possible backlash .
You do have the added complication of a feed shaft and lead screw so would need to decide if just the leadscrew was going to be used all the time or still have a way to use the feedshaft for manual machining (assume the handwheels can still be used? )
Few videos of it in action on their channel
Kiwi Bloke05/04/2021 10:54:18
912 forum posts
Jan Sverre Haugjord puts interesting videos up on the 'Tube. Several are about the ELS. Quite a few on scraping, too.
duncan webster05/04/2021 12:55:07
5307 forum posts
83 photos
I made a ELS to the design by Joe Noci, I wouldn't be without it now. All up cost probably well under £200, but I didn't keep track
ChrisB05/04/2021 15:05:19
671 forum posts
212 photos
Hadn't thought of the gearbox and feed shaft, probably could work if left on the A selector Jason, but not being directly driven backlash would be a problem for threading I think. As for manual control, reading through the manual, it can be manually controlled and the handles should stay.
JasonB05/04/2021 15:48:39
The other option would be to drive the leadscrew from the tailstock end, should be enough sticking out the end of the bracket to fit an adaptor to. Then you can just use the gearbox to drive the feed shaft and never move the selector to screwcutting position.
That will get rid of any backlash in the leadscrew, you just need to sort out the cross slide screw backlash if you want to do say ball cutting as cross slide will need to move in both directions.
ChrisB06/04/2021 10:43:19
671 forum posts
212 photos
That would be a good option Jason. That will give me two modes of operation, either in manual control with automatic feed as the lathe came originally, and ELS control via the leadscrew.
Reading through the manual, there is an input for "X" and "Z" axes backlash, so the ELS will compensate for this during radius turning.
Oily Rag09/04/2021 14:39:35
550 forum posts
190 photos
I am considering building a CNC cam grinder. This would involve either a stepper driven leadscrew for positioning the saddle longitudinally along the bedway and a ball screw driven by a stepper for the cross slide. The cam would then be formed by controlling the relative position of the cross slide to the rotation of the headstock spindle (by use of an encoder). The encoder would need absolute positioning capability so would likely have to be something like a 4k 'greyscale' type.
My concern is would the reaction time of the cross slide be sufficient to accurately grind the cam form given that the peak acceleration/deceleration rate of a cam can be in the region of 0.006" per degree. The ideal speed of the cam for grinding would be around 300 rpm to allow a small enough grinding wheel (running at close to 4,500 rpm) to fit into the space needed. this gives a time per degree of 0.00055 secs which equates to a cross slide speed of nearly 11" per second or 54.5 ft per minute.Can the control systems, both software and hardware, handle these type of positional reaction speeds?
I realise that 'professional' systems are capable of these sort of speeds but are the 'hobby' systems capable likewise? Any comments and suggestions would be most welcome.
As an additional note the reason for building the cam grinder is that I have a 'spare' bed and headstock and saddle that can be modified - It's too good to scrap and it seems a worthwhile project to make some use of it rather than leave it to 'rust in peace'
Martin
John P10/04/2021 11:42:49
451 forum posts
268 photos
Posted by Oily Rag 09/04/2021 14:39:35
reaction speeds?
Martin
Hi Martin
First of all the speed that you indicated seems a little high,
in this video
https://youtu.be/7vz-Z6x5ZLw
the cam is rotating at between 30 to 40 rpm that alone
would solve some of the points that you have raised.
As part of a project that i have still on going i have looked in to
grinding similar forms ,the photo here shows the machine set up here
with the stepper motor drive controlling the rotation of the camshaft axis
( the shaft fitted here is for something else not a cam)
at 1800 steps per rev, the crosslide moves 0.00005 inch per step.
I wrote a small file to simulate a camshaft but found like you , the
speed as the grinding wheel goes over the peak of the cam the
speed can be too high ,as part of the sequence the rotation speed
of the cam is incrementally reduced and increased as the grinding
wheel rises up and falls over the cam lobe ,i never got to the point
of cutting metal but some of the things that are gained just by these
simulations are of value.
The other thing to think about is at some point during the grinding if you
are using the encoder and crosslide to follow the cam shape
the crosslide will need to move independently to increase the cut depth,
unlike using these systems for threading the grinding is more of a
continuous sequence.
The rocking action of the cam being ground in the video almost
seems like the easiest solution and use the cnc part to make the
master cam.
Oily Rag10/04/2021 18:09:44
550 forum posts
190 photos
John,
Thank you for your valuable comments.
I needed to run the component at around 300rpm to give the correct surface speed for a small(ish) grinding wheel. As shown in the YT videos of the professional cam grinders the wheels tend to be quite large diameter. The 'rocking bed' system was originally pioneered by Brown & Sharpe in their cam grinders but the basis of my machine needed to be based on a fixed bed to utilise the old lathe bed, although admittedly I could build a rocking system to superimpose on the bed itself. The requirement for the master cam and follower (which must mirror the wheel diameter and requires a host of followers to allow for wheel wear) is something I'm trying to avoid. Ideally I therefore want to go from a CAD design straight to the cam form.
I have built one before, about 30 years ago, from a lathe bed and it was very successful in what it did. However it used a hydraulically driven cross slide which was able to achieve very high rates of movement, it did require a separate hydraulic power pack to drive it with 200 bar pressure and used Moog valves to control the motion. We adapted an engine ECU (64 bit) with a dual encoder using hall effect pickups and a 60+1 tooth master spindle trigger wheel and a secondary 29 tooth trigger wheel (to give differentiation) to allow a resolution of 0.06 degree.
I agree with you about the 'nose' speed problem. That can be solved by a programmed variable speed applied to the main spindle, I think!
The infeed would be performed by continual offset steps down to a pre-determined 'stop'. The offset steps only being allowed when motor current indicates the current 'step cut' has diminished to a near 'spark out' level. Or it could attempt to maintain a set motor current level and apply off setting steps accordingly???
Thanks again for your valued contribution.
My apologies to the OP for hi-jacking his thread, I suppose this did deserve a 'New Thread' but sometimes it is easier to jump in when the thread has either got 'tired' or reached a conclusion.
Martin
John P11/04/2021 11:28:57
451 forum posts
268 photos
Hi Martin
Seeing what you have written it would seem that you may be grinding a full size
cam perhaps not for model size engines ,your smallish grinding wheel would be
about my normal size wheel 6 to 7 inch where the difference in size for a cam
blank of about 1/2 inch shows little error from a radius to a straight line.
For the model engine enthusiast these two videos from Sherline may be of
interest. Certainly for me , on seeing these my early attempts i was trying to run
the work perhaps too fast ,the attraction of doing these with cnc is there is little
more to make if you already have a machine as i have.
https://youtu.be/RrpdJHTPXFI
https://youtu.be/PffRGZjagBs
Perhaps you will write again about your cam grinding as it progresses most
probably in its own new thread ,i am sure it will be of great interest.
jaCK Hobson23/08/2023 14:30:08
383 forum posts
101 photos
I'm currently installing on an old Super 7. It is a cheap way of getting the equivalent of power cross feed and gearbox (gearbox alone now goes for the cost of the complete kit).
I could easily pull it all off if I switched machines.
The challenge with the install is how to physically connect the components : spindle encoder, x and Z motors.
Some observations:
I have the 'hidden under the cross slide' DRO from machine DRO and this would complicate putting the Z motor on the back of the cross slide (where it would probably look nicest. So I'm putting mind on the front, using a bracket bolted to cross slide T-slot.
The toothed belts/wheels for printers (and 3D printers) are cheap and good for light loads. '2GT' 2mm pitch 6mm wide. Lots of options next day delivery on Amazon. Excellent for spindle encoder... but I didn't find them until I had already used 5mm pitch 10mm wide. I will see if it is enough for cross slide.... an 80 tooth wheel replaces the dial gauge while retaining the handle which is really neat. 60 tooth might work and be even neater.
Certainly happy to stick with bigger belts for leadscrew. I put it on the handwheel end.
Document from rocketronics suggests not to gear down steppers too much (steppers lose torque at higher revs so gear down for torque doesn't always help) and stick to whole ratios.
Now I just have to wire it all up...
John Hinkley23/08/2023 17:32:30
1545 forum posts
484 photos
ChrisB
i fitted a Clough42 els to my Asian 9x20 lathe. It doesn't have the bells and whistles of the Rocketronics one, but all I wanted was the convenience of button selectable feed rates and inch/metric threading. I had already made a ball turning accessory and later, a taper turning attachment. The installation is briefly described in an album and more extensibly in a YouTube series of videos. I didn't keep track of the total cost either, but I'd be surprised if it came to more than £350. That includes two Texas Instruments Launchpads, 'cos I managed to fry one somehow.
Edited By John Hinkley on 23/08/2023 17:34:23
