ron vale 1 | 22/03/2021 11:55:38 |
50 forum posts 5 photos | Is there anywhere that supplies files that are either 0.25in or 6mm thick
Am about to file the expansion link and liiftng link slots in the radius rod Whilst the slotting is no problem, i need a file of that thickness to get the ends 'square' Or is there a better way i am not aware of? |
Grindstone Cowboy | 22/03/2021 12:05:12 |
1160 forum posts 73 photos | Quick look at Arc Euro reveals these, but there are no doubt other suppliers available. Rob
Links to https://www.arceurotrade.co.uk/Catalogue/Cutting-Tools/Tome-Feteira-Files/Engineering-Files/Flat-Files |
Martin Kyte | 22/03/2021 12:29:09 |
![]() 3445 forum posts 62 photos | Grind up a triangular file so you have two safe edges either side of the active face maybe. regards Martin Edited By Martin Kyte on 22/03/2021 12:29:24 |
ron vale 1 | 22/03/2021 16:34:41 |
50 forum posts 5 photos | Grindstone
Thanks Had a complete brainfart fort hem!!
^mm will be just the job |
Mick Henshall | 22/03/2021 20:37:58 |
![]() 562 forum posts 34 photos | Had a look at Arc's files, does the length given include the tang or just reter to the file's cutting section? Mick 🇫🇴🇫🇴 |
Rod Renshaw | 22/03/2021 20:53:02 |
438 forum posts 2 photos | Can't speak about Arc, but it is conventional to ignore the tang when measuring the length of a file. Rod |
Mick Henshall | 22/03/2021 20:58:23 |
![]() 562 forum posts 34 photos | Thanks Rod, I am making the filing machine designed by Harold Hall an trying to work out the length of file needed Mick 🇫🇴 |
