Brian H | 06/03/2021 15:18:15 |
![]() 2312 forum posts 112 photos | I have made 2 oilers from glass globes and brass. Does anyone know if superglue is affected by oil once it is cured? Brian |
Brian Wood | 06/03/2021 17:54:01 |
2742 forum posts 39 photos | Brian H Loctite make an oil tolerant 603 retaining compound which should work in your case. Regards Brian [another] |
Ramon Wilson | 06/03/2021 18:39:36 |
![]() 1655 forum posts 617 photos | Brian I have made several oilers over the years using the Slo Zap super glue. This does not fog and no I've not had any fail though oil. Sometines the glue does become a bit brittle with age and a slight knock might unseat it but it is soon re- glued. I must point out though I have not used glass but clear plastic tube - either the clear tube that protects artist type paint brushes or the clear tubular enclosures that some cutting tools have. I have used glass on the aquariums on the Corliss engine.
Tug |
Brian H | 07/03/2021 08:20:52 |
![]() 2312 forum posts 112 photos | Many thanks for the answers Brian & Tug, as it happens I have a bottle of Loctite 603, just never thought of using it. From Tugs answer it would seem that a normal superglue would be OK. The one that I have used is fairly thick and is not an instant one, meaning that repositioning is possible for a short time. Brian |
ega | 07/03/2021 16:21:59 |
2805 forum posts 219 photos | As we have moved on to Loctite, may I mention that 603 is also tolerant of surfaces which are not "consistently clean" and it can be used for gluing oil impregnated bushes into housings. According to the data sheets, 601, 603 and 638 all appear to have similar resistance to oil after cure. |
Ramon Wilson | 07/03/2021 17:04:38 |
![]() 1655 forum posts 617 photos | Just to say Brian Pacer products Slo Zap is a medium thick CA which unlike the fast does not have a tendency to fog Loctite of course is anerobic so works best when gaps are at a minimum. I've found acetone to be the best clean up for CA and always use Methylated spirits for Loctite - it kills it dead! |
Pete Rimmer | 07/03/2021 19:19:04 |
1486 forum posts 105 photos | Araldite is also fuel and oil proof once cured. The nromal cure stuff not the rapid one. |
Brian H | 08/03/2021 11:35:26 |
![]() 2312 forum posts 112 photos | I never considered Araldite, even though I have some! Many thanks to all who replied, you've been very helpful. Below is a picture of one of the oilers, it just needs a split pin and some worsted thread to complete. The glass globe is 5/8"inches in diameter. Brian |
