3D Printed CNC soft jaws for work holding
Alan Wood 403/02/2021 12:10:53
257 forum posts
14 photos
In the ME world I have come to realise that nothing is ever new and it has always been done by someone else some other time and probably better with a plethora of internet links to back this up. The result is many of us feel inhibited in making contributions to forums fearing we open ourselves to criticisms, NIH responses and other such belittlements .... but here goes.
Using CAD/CAM it is relatively easy to create soft jaws to hold complex shapes while undertaking machining operations. Normally this is done by creating mirror image cavities in aluminium soft jaws mounted in place of the standard jaws in the machine vice.
Where the need is just for a simple work holding to deck off side two stock I have had a great success using 3D printed soft jaws. They are quick and easy to design in Fusion using the Project function. They can be 3D printed as a background operation rather than loading the mill with the need to machine aluminium versions.
It is not a panacea for the need to use complex high accuracy metal soft jaws but for simple decking operations it is very useful technique.
So accepting that someone somewhere is probably already doing it, think of this as a reminder of an option to put in your armoury. There are a couple of examples here of clock related parts I have run using this technique.
DrDave03/02/2021 12:29:19
264 forum posts
52 photos
That looks to be a really useful method of holding delicate work: why didn’t I think of it? A 3D printer is rapidly moving from my “desirement” phase to my “must have” phase.
Thanks for sharing this.
Bazyle03/02/2021 12:35:05
6956 forum posts
229 photos
Wow, that clock wheel holder is taking custom jaws to the extreme. Looks like your site is full of interesting stuff so bookmarked for reading tonight.
Alan Wood 403/02/2021 12:42:23
257 forum posts
14 photos
Thank you DrDave and Bazyle, glad you found it interesting and maybe of use.
Alan
Dave Smith 1403/02/2021 12:50:21
222 forum posts
48 photos
Alan
Great use of modern tech. Like I also use my FDM printer for assembly fixtures, drill jig etc. For anyone thinking about do the same, you need to be careful when machining or milling not to generate a lot of heat or you will soften or melt the plastic!
Dasve
old mart03/02/2021 20:00:38
4655 forum posts
304 photos
Pratt Burnerd used to make specialist soft jaws for some of their smaller chucks from nylon, you would have to be careful not to snap off the scroll teeth.
AJAX03/02/2021 20:04:06
433 forum posts
42 photos
Posted by DrDave on 03/02/2021 12:29:19:
I didn't rate 3d printers much until I recently tried printing change gears for my lathe. They are excellent!
