Dome bush
Bill Dawes21/01/2021 19:13:31
605 forum posts
Hi all, an issue that has nagged at me ever since i started soldering up my boiler, should the dome bush have been profiled to fit the curvature of the boiler. The drawing (Emma Victoria) does not seem to show this so it was done as the words and music meaning of course that it is retained by the silver solder just around the hole in the boiler shell rather than over the greater area of the bush diameter.
None of the other top bushes are profiled but they are not so large and therefore less obvious.
Just finishing off the smokebox stays so pretty much finished (well until I pressure test and find I have tp start again!!)
Appreciate your experiences guys.
Bill D.
Former Member21/01/2021 19:16:49
1085 forum posts
Clive Brown 121/01/2021 19:26:06
1050 forum posts
56 photos
5" gauge presumably. It's not usual to profile a dome bush, so your boiler will be ok in that respect. Just needs to have sufficient length to project into the boiler at the sides of the bush.
fizzy21/01/2021 21:06:02
1860 forum posts
121 photos
it wouldnt be possable to profile a bush and still have it going into the boiler, unless your bush just sat on the outside of the shell. Either way if youve got it silver soldered in and there are enough threads it makes no difference.
