Question from members who have experience of servicing a lathe
Robert Trethewey | 07/11/2020 16:39:30 |
![]() 17 forum posts 40 photos | Hi: Everyone - on the 2nd of May 2019 IFoggy wrote that he'd found a small piece of iron in one of the gears of his Myford 254V Plus lathe which caused a vibration when using the lathe's back gear - I'd very much appreciate knowing how he actually found the offending piece of metal as I may have a similar problem effecting my machine to a small amount but I'd like to ensure that this doesn't develope into a real problem. My Myford 254V plus can be seen on www.ritasears.blogspot.com look at tab "R" if you're interested in seeing the rebuild of a Myford KF-MC-C milling machine which will shortly be fitted with a three axis DRO and a home built power drive on it's longitudinal table look at tab"O"
Chris Pearson 1 | 07/11/2020 18:30:16 |
189 forum posts 3 photos | Are you able to measure the frequency of the vibration (against spindle speed)? That ought to give you an idea where to look. |
Robert Trethewey | 07/11/2020 18:58:02 |
![]() 17 forum posts 40 photos | Hi: Thanks for coming back to me so quickly - I don't have anything to measure the vibration. I can hear and feel a very slight knocking - this is why I looked up posts about bearing setup and adjustment thinking it was a loose bearing which could be the case as the previous owners, a technical college in London, who's engineers had done little or no maintenance since the machine was first supplied to them. |
