Bantam gearbox oil filling
Nick Belton | 05/11/2020 15:45:45 |
6 forum posts | Good afternoon all, After a while of reading the manual and googling, i am a bit stuck.. I have a colchester 1600 bantam, i need to fill the headstock and gearbox with oil, headstock is fine, a nice big cap to unscrew to fill it, perfect, but, i cannot see where i fill the screw cutting gearbox? can anyone shed some light to help? thank you! nick |
Simon Williams 3 | 05/11/2020 19:25:16 |
728 forum posts 90 photos | Take off the fibreglass gear cover (LHS of lathe). There is a knurled plug about 25 mm dia on top of the curved surface of the cast cover LHS of the gearbox. It's got a breather hole in the centre. Its just in front of the 100/120 gear cluster. Unscrew it and there is a 20 mm or thereabouts filler hole below. HTH Simon
edit If you have a copy of the manual, it's the lower picture on page 6 of the parts book, If you need a copy I can't do it now the wife is on the scanner, but I'll add a picture later Edited By Simon Williams 3 on 05/11/2020 19:29:16 |
Nick Belton | 05/11/2020 19:45:12 |
6 forum posts | Thank You Simon, i see the bit now! The manual does not help much here! Even on how much oil the headstock and gearbox hold.. (luckily i found the answers to that on here in another post!). Much appreciated and thank you again, nick. |
Emgee | 05/11/2020 20:21:45 |
2610 forum posts 312 photos | Nick I recently checked the oil level in my Bantam lower box but found the oil level sightglass was very stained and I couldn't see the oil level so thought it must need topping up. I found this out by drilling a hole in the centre of the plastic sightglass and allowed 1.5 pints to drain out. Emgee Edited By Emgee on 05/11/2020 20:22:19 |
Simon Williams 3 | 05/11/2020 20:36:58 |
728 forum posts 90 photos | You've got me going now. But the manual does have oil fill capacities, they just hid 'em. Page 18/19 of the User Manual says the headstock takes 6 pints, the gearbox takes 1 pint. Suggests Shell Tellus 27, but that's just a general purpose thinnish hydraulic oil. I use 30 grade in a hydraulic hedge trimmer, I'm sure that'll do the job. Rgds Simon |
Nick Belton | 13/11/2020 10:40:37 |
6 forum posts | Thank you for all of the replies, you have all been of great help! And its all done. (Sorry for the late response, i am moving house, and its been a nightmare, forgetting how heavy some of my machinery is!) nick. |
