Member postings for Nick Belton
Here is a list of all the postings Nick Belton has made in our forums. Click on a thread name to jump to the thread.
Thread: Elliott milling machine table safe weight
11/07/2023 20:16:42
Thank you for all of your responses.
Clive/Nigel, i think the weights i will be using are quite safe! (Doubtful i will ever go over 100kg).
Bazyle, its one with dovetails and the knee is motorised, but can also be operated with a handle.
Not Done It Yet, The table is 50 inches, so clamping and placement should be good for my modelling needs!
seems extreme for such a large machine, when i mostly do odds and ends, 7 1/4 gauge railway, and Mk1 Mini restoration work, but i had a small Warco, but that was too small, then this elliott is available, close to home and a good price, so hard to refuse!
09/07/2023 20:15:32
Thank you Old Mart, and thank you for your welcome.
it is a big machine, (same size as a bridgeport), so i know its sturdy but i dont want to risk putting too much weight on it! My rotary table and dividing head are not going to be a problem then! (Less than 50kg) and i dont do real heavy work.. i find it odd the manual did not say its limitations!
thank you again!
nick
09/07/2023 16:30:02
Good afternoon all,
I have just purchased an Elliott Supamill 10, i have the manual, but it does not say how much weight the table can hold, Does anyone have any suggestions or can help?
thank you!
nick
Thread: Bantam gearbox oil filling
13/11/2020 10:40:37
Thank you for all of the replies, you have all been of great help! And its all done. (Sorry for the late response, i am moving house, and its been a nightmare, forgetting how heavy some of my machinery is!)
nick.
05/11/2020 19:45:12
Thank You Simon, i see the bit now! The manual does not help much here! Even on how much oil the headstock and gearbox hold.. (luckily i found the answers to that on here in another post!).
Much appreciated and thank you again,
nick.
05/11/2020 15:45:45
Good afternoon all,
After a while of reading the manual and googling, i am a bit stuck..
I have a colchester 1600 bantam, i need to fill the headstock and gearbox with oil, headstock is fine, a nice big cap to unscrew to fill it, perfect, but, i cannot see where i fill the screw cutting gearbox?
can anyone shed some light to help?
thank you!
nick
