sam sokolik | 22/10/2020 15:59:05 |
126 forum posts | Some more fun with cnc...
Michael Gilligan | 22/10/2020 22:39:22 |
![]() 23121 forum posts 1360 photos | Clever stuff, Sam Keep sharing your adventure MichaelG. |
DC31k | 23/10/2020 08:27:59 |
1186 forum posts 11 photos | A couple of questions: Right now, it is effectively converting a closed shape into a series of (X, A) coordinate values, where I guess the A- increment can be arbitrarily small. How easy would it be to make it turn 90 degrees and produce (Z, A) values? I am thinking of a face cam, as used in Brierley and Rush drill grinders. https://rushmachinery.com/products/drill-and-tool-grinders/model-132c/ Second, does it have any built-in idiot-proofing? If I sent it a circular hole with a keyway cut out, would it tell me to go away and pound sand due to the discontinuity in the profile? As a corollary to this, what is the most acute internal angle with which it is comfortable (e.g. an equilateral triangle-shaped bore)? Thanks. |
Nigel Graham 2 | 23/10/2020 09:04:43 |
3293 forum posts 112 photos | I'm not an expert on CNC machining but I don't think the keyhole would be a problem unless the corner radii are very critical . Rather, won't the minima on milling internal dimensions including angles, be controlled by practical machining criteria like the diameter and lengths of the cutters, more than the tool paths? I recall seeing a drawing at work of something resembling the internal profile of a hollowed stepped pulley, in which one of the steps was shown with a small pocket, perhaps for a form of key, milled into it. The pocket's size and 2mm corner radii were so small, and it was so far down the overall cavity, I could not imagine how it could be machined with any standard slot-drills. |
