Some interesting short videos ...
Michael Gilligan | 23/09/2020 09:47:30 |
![]() 23121 forum posts 1360 photos | I don’t use Facebook, but I stumbled across these whilst searching for something this morning: **LINK** https://www.facebook.com/PPThorntonsuccessors/videos/10201053960773462/ MichaelG. |
John Haine | 23/09/2020 10:29:27 |
5563 forum posts 322 photos | Good link, thanks Michael! Now if we had a video of how they shape the profiles on their HSS blanks... |
Michael Gilligan | 23/09/2020 11:14:39 |
![]() 23121 forum posts 1360 photos | Posted by John Haine on 23/09/2020 10:29:27:
Good link, thanks Michael! Now if we had a video of how they shape the profiles on their HSS blanks... . The frustrating thing, John, is : I’m sure I have seen one [or at least some photos] years ago. They cut the HSS with a carbide profile tool, in the lathe, I believe. MichaelG. |
ega | 23/09/2020 14:15:37 |
2805 forum posts 219 photos | I hastened to view MichaelG's linked video lest it be censored (I admit I don't feel sure about the working of the new rules). I suppose that the oil in the sump beneath the cutter is there to capture any grinding dust that doesn't go into the funnel? |
Michael Gilligan | 23/09/2020 15:10:28 |
![]() 23121 forum posts 1360 photos | John, Thanks to the wonderful digital archive ... and to my own search skills I have, at last, found what is probably the definitive article about cutter manufacture at PP Thornton (successors) . Horological Journal December 1995 pp 416-418 by J K Nicholson . MichaelG.
John Haine | 23/09/2020 15:46:24 |
5563 forum posts 322 photos | Aha! Good stuff, I'll peruse that. |
John Haine | 23/09/2020 17:53:09 |
5563 forum posts 322 photos | Well, that was an interesting read Michael! Not entirely clear, but it seems that they produce the cutters using in effect the "button" method to impart the required profile to the teeth, the "buttons" (or their equivalent) being made from carbide, ground to shape using diamond wheels. The "soft" 12-tooth HSS blank is turned on a form-relieving lathe after gashing, then vacuum heat treated to harden. Doesn't sound easy to reproduce at home! |
Baz | 23/09/2020 18:02:00 |
1033 forum posts 2 photos | John Haine if you substitute gauge plate for soft HSS and use the Ureaka form relieving attatcment it is perfectly do-able in the average workshop. |
Michael Gilligan | 23/09/2020 18:32:18 |
![]() 23121 forum posts 1360 photos | Posted by John Haine on 23/09/2020 17:53:09:
Well, that was an interesting read Michael! Not entirely clear, but it seems that they produce the cutters using in effect the "button" method to impart the required profile to the teeth, the "buttons" (or their equivalent) being made from carbide, ground to shape using diamond wheels. The "soft" 12-tooth HSS blank is turned on a form-relieving lathe after gashing, then vacuum heat treated to harden. Doesn't sound easy to reproduce at home! . Not forgetting the pantograph reduction, and the inspection work .... suddenly, it makes the price look very reasonable MichaelG. |
John Haine | 23/09/2020 18:40:38 |
5563 forum posts 322 photos | Posted by Baz on 23/09/2020 18:02:00:
John Haine if you substitute gauge plate for soft HSS and use the Ureaka form relieving attatcment it is perfectly do-able in the average workshop. Indeed, but in another thread people have been discussing manufacture of HSS tools on the Quorn. |
Martin Kyte | 23/09/2020 20:00:53 |
![]() 3445 forum posts 62 photos | Posted by Michael Gilligan on 23/09/2020 18:32:18:
Well, that was an interesting read Michael! Not entirely clear, but it seems that they produce the cutters using in effect the "button" method to impart the required profile to the teeth, the "buttons" (or their equivalent) being made from carbide, ground to shape using diamond wheels. The "soft" 12-tooth HSS blank is turned on a form-relieving lathe after gashing, then vacuum heat treated to harden. Doesn't sound easy to reproduce at home! . Not forgetting the pantograph reduction, and the inspection work .... suddenly, it makes the price look very reasonable MichaelG. Especially as they do a sharpening service at half the price of the cutter. regards Martin |
