problem
Nic Bertelsen | 20/09/2020 10:14:50 |
6 forum posts 2 photos | Hi, ive got a wm240v which I nipped up yesterday when parting off work. Motor stopped and now won't restart. When I turn on the rpm screen flashes 1469rpm then 0 rpm and stays on 0. There is no motor movement. Any ideas? TIA |
AlanW | 20/09/2020 17:11:41 |
92 forum posts 12 photos | Hi Nic Check the fuses on the control panel. You may have got away lightly but, if not, it could be the control board gone phutt. These variable speed dc lathes are not very forgiving of stall conditions; you need to be very quick on the stop button. They are very easy to stall anyway, despite the alleged 1hp motor. I added an intermediate pulley pair to my 240 to increase low-speed torque and avoid just this kind of problem. Alan |
Nic Bertelsen | 20/09/2020 17:31:20 |
6 forum posts 2 photos | Hi, i checked the fuse in rear of machine and it was fine, are there others I haven't found yet? Mines not too bad for stalling as the previous owner installed a bigger motor onto lathe to combat this, I was just not concentrating as much as I should have been grrr. Nic |
not done it yet | 20/09/2020 18:22:09 |
7517 forum posts 20 photos | They are very easy to stall anyway, despite the alleged 1hp motor. Specification says 1.1kW. So Warco also quotes input power and not the real output power? I am surprised - well, perhaps not. Edited By not done it yet on 20/09/2020 18:22:37 |
AlanW | 20/09/2020 18:23:45 |
92 forum posts 12 photos | Mine has two fuses, one on the front panel and one on the back. |
AlanW | 20/09/2020 18:44:51 |
92 forum posts 12 photos | NDIY I can only speak as I find. When I needed the torque at low revs turning a large diameter, it just wasn't there. My old Hobbymat with 300W ac motor would have coped easily where the 240 stalled. Nic If the motor has been changed (presumably up-rated) what other mods may have been done to the electrics? Alan |
Sam Longley 1 | 20/09/2020 21:26:30 |
965 forum posts 34 photos | Mine stalls several times a session. Gutless thing. Less power than my old Drummond M type. takes several presses of the stop/start button to get it going even if it has not had a stall. If I forget to press the stop button after a stall or after i have pressed the start button & it has not started, it sometimes starts whilst i am doing a set up, which has caught me unawares a couple of times with my hand on the chuck.
Edited By Sam Longley 1 on 20/09/2020 21:30:03 |
