Richard Cox | 01/09/2020 21:22:20 |
60 forum posts 19 photos | evening all quick question I have a three phase compressor that has been running off a 230v three phase inverter the motor was configured in delta, I’m lending it out to someone who has three phase on site, do I just swap the terminals to star configuration, i guess what I’m trying to ask is dual voltage motor if 415v then motor should be configured in star if 230v then should be configured in delta regards Rich |
Emgee | 01/09/2020 21:32:32 |
2610 forum posts 312 photos | Configure to High voltage by swinging the links over, make sure he has a suitable starter but you don't mention HP. Emgee |
Richard Cox | 01/09/2020 22:16:23 |
60 forum posts 19 photos | Hi emgee it’s a 5.5hp no starter, so the u2 v2 w2 should all linked with the busbars/straps And the u1 v1 w1 should have the phases connected Rich |
Emgee | 01/09/2020 23:56:13 |
2610 forum posts 312 photos | Hi Richard Best to use a starter with any motor, especially that size if running at 3 phase 415v, or better still leave it delta connected and send your inverter which hopefully has some fault and overload protection on the output. Emgee |
Steviegtr | 02/09/2020 07:40:45 |
![]() 2668 forum posts 352 photos | Posted by Richard Cox on 01/09/2020 22:16:23:
Hi emgee it’s a 5.5hp no starter, so the u2 v2 w2 should all linked with the busbars/straps And the u1 v1 w1 should have the phases connected Rich Yes. But do not just rely on an isolator for switching. They are not meant for that. Steve. |
Richard Cox | 02/09/2020 08:40:05 |
60 forum posts 19 photos | Hi Steve it will utilise the pressure switch on the compressor for stopping and starting Rich |
Steviegtr | 02/09/2020 16:48:36 |
![]() 2668 forum posts 352 photos | Posted by Richard Cox on 02/09/2020 08:40:05:
Hi Steve it will utilise the pressure switch on the compressor for stopping and starting Rich Steve. |
