Phil Boyland | 27/08/2020 09:33:58 |
![]() 49 forum posts 13 photos | Hi, can anyone recommend a motor overhaul place in the Derby area. My lathe motor has developed an issue so need to get it looked at. Cheers
Hopper | 27/08/2020 09:55:21 |
![]() 7881 forum posts 397 photos | Changing the bea rings yourself is a very easy job and will save you a lot of money over getting it done. They would have to be pretty bad to stop the motor turning altogether though. Could be a problem with start windings and associated switch or capacitor. In which case things get more complicated but not beyond the scope of the home workshop. Easiest way to check the bearings is to take the belt off and spin the motor pulley by hand. Should feel nice and smooth with no lumpiness or binding. Edited By Hopper on 27/08/2020 09:56:46 |
Dave Daniels | 27/08/2020 10:05:59 |
87 forum posts | Posted by Phil Boyland on 27/08/2020 09:33:58:
Bowers Electrical Heanor ?? You could try them but they are at the 'big stuff' end of the trade. Could well be cheaper to get a new motor. Used to use a firm in ( Shaftesbury St. ? ) but I think they're long gone.
Brian Wood | 27/08/2020 10:16:18 |
2742 forum posts 39 photos | Hello Phil, It is many years now since I was based in Derby but a Google search produced the following:- Long Eaton Rewinds Ltd, Unit 3 Langham Park, Stanton-by-Dale DE7 4RJ Phone 01332 873118 I have no knowledge of the organisation whatsoever, you are on your own with that Your fault description sounds like a start capacitor failure if your motor is fitted with one, they usually live in the round bulge on the outside of the motor. It is either that or the starter switch built into the motor which now has dirty contacts. The least likely fault is a winding failure It will mean taking the motor apart to clean the switch, the capacitor would be a simple replacement part. If you are unhappy with that sort of work any competent sparkie will do it for you and test the windings. Regards Brian Edited By Brian Wood on 27/08/2020 10:18:22 |
Howard Lewis | 27/08/2020 14:50:20 |
7227 forum posts 21 photos | +1 for Brian's suggestions of either a failed Start Capacitor, or a faulty centrifugal switch. Howard |
Phil Boyland | 27/08/2020 20:29:04 |
![]() 49 forum posts 13 photos | Ok that’s great cheers for the info. I’ll have a go myself first, best regards phil |
