How to?
Half centre | 24/08/2020 17:02:07 |
32 forum posts 1 photos | Hi folks - I was wondering if anyone had any tips for separating the front and back of small pressure gauges. With the two I have the back slides into the front telescopically. This seems to be a very common fitting. The fit is very tight and I have yet to find an "easy" way to separate the two halves to enable me to mark the red line on the scale. Any thoughts gratefully received Martin |
Zan | 25/08/2020 11:11:04 |
356 forum posts 25 photos | Hold the outlet vertically in the vice. The mech is usually attached to the body “cup” then carefullyAnd gently punch the bezel off. Worked perfectly on all mine |
Half centre | 25/08/2020 18:52:03 |
32 forum posts 1 photos | Thanks Zan - That sounds an excellent idea - I will give it ago. Martin |
Nigel Graham 2 | 26/08/2020 21:57:21 |
3293 forum posts 112 photos | Thank you both Half centre for asking, and Zan for replying: I am faced with the same difficulty! I think I would use a scrap of semi-rigid plastic or wood, possibly aluminium, as punch. |
Half centre | 27/08/2020 18:12:35 |
32 forum posts 1 photos | Just tried it and it worked a treat. Gentle tapping with a small hammer and an aluminium rod as a punch. Careful to move it around the circumference to get an even movement. Found 2 raised pips formed on the inner casing I presume deliberately to create grip. Sanded them a little flatter, grip still adequate but now far easier to separate. Thanks again Zan Martin |
