Arbour dia and length for Commercial Clock Wheel Cutters
Chris TickTock18/08/2020 13:50:28
622 forum posts
46 photos
Hi Guys,
I intend experimenting with a commercial clock wheel / pinion cutter. I have looked at a few sites but am unsure on a few points. Could any one help?
firstly My Mill is Sherline and Sherline do supply commercial cutter arbours as follows:
7/8 dia arbour. These come as short or standard length.
1 inch dia arbour again in short and standard length.
So are most( relevant to clock work) cutters in the UK 7/8 or 1 inch and is the standard length a better first time purchase over the longer standard arbour. I imagine the different arbour lengths are to accommodate z axis space but as yet I am fairly ignorant over these matters.
Chris
Martin Kyte18/08/2020 14:16:42
3445 forum posts
62 photos
Presumably you have a lathe, why not turn up your own arbors to suit whatever you are doing.?
7/8" and 1" sound like arbors for Gear cutters which are generally larger than clockmakers cutters.
Typical PP Thornton pinion cutters are 24mm dia around 4.5mm thick and have a 7mm bore.
regards Martin
Chris TickTock18/08/2020 15:05:03
622 forum posts
46 photos
Posted by Martin Kyte on 18/08/2020 14:16:42:
regards Martin
Thanks Martin,
As i am not yet retired time can be a big restraint and I still would need to know the right size arbour to make so your detail is useful. I have some old I would imagine involute cutters I was given with a 25mm bore. I have been advised these can be used to touch up teeth or leaves but hey as yet I have little idea, so asking as much as possible along side my research.
Chris
Steve Crow18/08/2020 15:48:14
429 forum posts
268 photos
Here's a Morse No1 arbor I made for my Sherline. Using the spacers and sleeves, it holds Thorntons Mod 0.5 cutters and 0.5 mm slitting saws at the same centre height.
Cheers
Steve
Chris TickTock18/08/2020 17:21:47
622 forum posts
46 photos
Posted by Steve Crow on 18/08/2020 15:48:14:
Cheers
Steve
Steve,
A big thank you, I am just ordering the lathe attachment to make the MT.
Chris
Martin Kyte18/08/2020 17:56:13
3445 forum posts
62 photos
You can buy 1 Morse blanks you know.
regards Martin
Peter Hall18/08/2020 18:00:13
115 forum posts
You don't need an attachment to make the MT. Just swivel the headstock to the right angle.
Pete
Chris TickTock18/08/2020 18:09:51
622 forum posts
46 photos
Thanks Guys, all helpful
Chris
John Haine18/08/2020 20:05:47
5563 forum posts
322 photos
Arbor! It isn't a leafy glade.
Chris TickTock19/08/2020 09:50:00
622 forum posts
46 photos
Posted by John Haine on 18/08/2020 20:05:47:
well spotted Jon
Chris
