Spark plug washers and Teflon shim
steamdave13/08/2020 22:51:42
526 forum posts
45 photos
Any ideas where I can get spare spark plug washers for 1/4" x 32 plugs?
I've had a look at Hemingway and S/S but they don't appear to have them. The copper washers on eBay are too wide (difference between inner and outer diameters)
While I'm at it, who sells Teflon (PTFE) sheet in 5 or 10 thou thick sheets? No luck on eBay or the usual ME suppliers. If all else fails,I can get copper shim 0.2mm thick. I suppose that would be OK instead?
The Emerald Isle
Georgineer13/08/2020 23:18:17
652 forum posts
33 photos
I can't help you with suppliers, I'm afraid.
You haven't said whether you are thinking of using the Teflon (PTFE) for spark plug washers, but if so, I wouldn't. It tends to creep under high temperature and pressure, which can cause problems.
George B.
JasonB14/08/2020 07:00:18
When I made the plugs for my RMC type B I also made the washers, Just drill a 1/4" hole in some thin copper sheet, mount on a mandrel and then turn the outside round. Or just turn down one sold for steam fittings.
I think non stick oven liner sheets are a source for the gasket material, at least that is what old John Bogs used to suggest. Plenty on e-bay. Mylar is another sheet that can be use dfor gaskets.
Edited By JasonB on 14/08/2020 07:02:17
JasonB14/08/2020 07:37:47
Just looked at Minimag, they do them
steamdave14/08/2020 14:45:11
526 forum posts
45 photos
Thanks, JB
I knew you would have the info!
The Emerald Isle
Andy_G14/08/2020 17:04:14
260 forum posts
Posted by steamdave on 13/08/2020 22:51:42:
As an alternative, glow plug washers would fit, wouldn't they?
steamdave14/08/2020 17:16:44
526 forum posts
45 photos
They will, but the question is still the same. Thankfully it has now been answered.
The Emerald Isle
Howard Lewis15/08/2020 12:06:53
7227 forum posts
21 photos
We found that using PTFE insulated cable when measuring injection pipe vibrations, that the material eventually vapourised at the high temperatures and corroded the conductors. Also, was told that the vapour was poisonous, because the PTFE breaks down. And Fluorine, or anything immediately derived from it, (such as HF ) is not good for health.
So use at low temperatures < 100'C would seem to safe.
