Garry Coles | 23/07/2020 14:14:39 |
![]() 121 forum posts 100 photos | Hi, I'm building the 2in scale D & NY Traction Engine and I want to make the cylinder studs, which the drawings state are 5BA that go into the boiler barrel in phospher bronze. But I can only find PB in 4BA size. Will this one size smaller be OK. There are in total 24 studs. Thanks Garry |
SillyOldDuffer | 23/07/2020 14:18:28 |
10668 forum posts 2415 photos | Good news! BA numbers run in reverse, so 4BA (3.6mm) is bigger and stronger than 5BA (3.2mm). Provided there's space to fit bigger studs, should be fine. Dave |
Clive Brown 1 | 23/07/2020 14:59:15 |
1050 forum posts 56 photos | 5 BA is almost exactly 1/8". Plenty of that available if you wish to stay to drawing. |
Garry Coles | 23/07/2020 16:18:33 |
![]() 121 forum posts 100 photos | OOPS ! I got the sizes back to front. I meant to say that the drawings say 4BA and I can only find PB in 1/8 5BA size. |
Harry Wilkes | 23/07/2020 16:21:38 |
![]() 1613 forum posts 72 photos | Hi Garry dont know if your talking about threaded rod or studs ? Studs are better here's a link to 5BA by 1" steel studs if they are of use to you H |
Baz | 23/07/2020 16:54:56 |
1033 forum posts 2 photos | Buy some 5/32 or 3/16 diameter bronze and turn it down, should be able to do it in one cut. |
Brian H | 23/07/2020 16:58:10 |
![]() 2312 forum posts 112 photos | I'd be surprised if this company cannot help; Brian |
duncan webster | 23/07/2020 16:58:14 |
5307 forum posts 83 photos | If there's room use M4, but the nuts are a tad bigger, so check first |
Harry Wilkes | 23/07/2020 18:09:33 |
![]() 1613 forum posts 72 photos | Posted by Brian H on 23/07/2020 16:58:10:
I'd be surprised if this company cannot help; Brian Good suggestion Brian but I think you'll find EKP have reduced the range of studs they used to offer H |
Garry Coles | 23/07/2020 19:54:33 |
![]() 121 forum posts 100 photos | Thanks everyone for your replies. I've already made up some 4BA steel studs but I wanted to use PB to get away from the corrosion of steel to the studs. I was going to use Stainless steel in the beginning, but some one said that's a no go for copper boilers! |
Harry Wilkes | 23/07/2020 21:07:38 |
![]() 1613 forum posts 72 photos | No stainless is not recommended for boiler studs and as far as using PB I would suggest steel is more commonly used H |
Garry Coles | 23/07/2020 22:19:12 |
![]() 121 forum posts 100 photos | Well in the end I think I will stick to using the steel studs I have already. Thanks everyone. |
Tim Stevens | 24/07/2020 21:57:16 |
![]() 1779 forum posts 1 photos | What is the problem with Stainless for this sort of job, then? Tim |
Baz | 24/07/2020 22:20:41 |
1033 forum posts 2 photos | Would have thought that stainless or bronze would be far better than steel, steel rusts doesn’t it? |
