Gary Brightman 1 | 19/07/2020 22:31:58 |
6 forum posts 8 photos | I have an 'Oxford' engineers' level similar to the Moore & Wright ELS. It has two holes/adjusters at each end (i.e. 4 in total) but the instructions don't clearly explain why there are two at each end. I'm thinking that the outer pair of holes might be locking screws and the inner ones are the actual adjusters. The instructions say not to over-loosen the outer screws as the vial could detach from the base which implies that they are locking screws but it refers to them as 'adjustment screws' which makes it rather confusing. Does anyone know exactly why there are two pairs of holes/adjusters and if the outer pair are actually locking screws? |
Pete Rimmer | 20/07/2020 05:45:23 |
1486 forum posts 105 photos | I would expect that the outside holes are threaded into the vial carrier so those screws 'pull' and the inside holes thread into the housing so they 'push', thus allowing adjustment with the facility to hold the vial very firmly. If you loosen either outside hole too much the vial carrier will fall off the screw. |
David Davies 8 | 20/07/2020 06:17:14 |
![]() 202 forum posts 1 photos | Gents I have a M & W ELS in bits in front of me. I still haven't got round to replacing the vial though I have obtained a spare vial. The outer screws hold the vial carrier to the level frame. The heads of the inner screws are beneath the vial carrier and 'jack' the carrier away from the frame.. Both bottom holes in the vial carrier are clearance holes, only the frame is tapped. The replacement vial was obtained from Cromwell tools. (I have no connection) HTH Dave
Gary Brightman 1 | 20/07/2020 19:30:14 |
6 forum posts 8 photos | Many thanks for the replies. So, if my understanding is correct (and the screws are normal R/H thread), the adjustment procedure would be... 1. Loosen both outer screws a small amount. 2. Perform the required adjustment using the inner screws (unscrew to raise vial holder that side). 3. Tighten the outer screws and re-check the calibration. 4. Repeat 1 - 3 as necessary. Gary |
Rod Renshaw | 20/07/2020 20:39:04 |
438 forum posts 2 photos | Yes, and quite a lot of repeats in my experience! Rod |
David Davies 8 | 20/07/2020 22:03:12 |
![]() 202 forum posts 1 photos | Gary at the risk of me stating the obvious the level must be swapped end for end on your reference surface after each iteration. The reference need not be level but the bubble must be in the same position for both orientations. regards Dave |
Gary Brightman 1 | 20/07/2020 23:00:16 |
6 forum posts 8 photos | Hi Dave, I didn't mention the 'swapping ends' bit in my original post as I didn't want to complicate the message but I do understand the process and I have a good surface plate. It was purely the arrangement of the screws in the four holes that I didn't get as it isn't explained properly in the instructions. Gary |
Mike Donnerstag | 24/07/2020 08:50:58 |
![]() 231 forum posts 53 photos | Thanks chaps - I bought a second-hand Moore & Wright ELS recently without instructions and, of course, it needed adjustment. I rang Bowers Group (who I understand own M&W) who told me that it was not possible to adjust it and there was no repair service! Not very helpful at all!! A good case of management too far removed from the manufacturing - they knew nothing about the product at all. I found through trial and error that the inner screws were there for adjustment, though I didn't know that the outer screws needed tightening afterwards, so I've learnt something there. Mike |
Martin Connelly | 24/07/2020 09:10:35 |
![]() 2549 forum posts 235 photos | I suspect the original production would have been set up with a calibrated low torque driver and a good reference surface to allow consistency in adjustment so making it easier. Variation in applied torque when tightening the outer screws will have you chasing your tail. Martin C |
john fletcher 1 | 24/07/2020 10:53:50 |
893 forum posts | i had a similar experience to Mike when I phoned Tyco Brook / Crompton motor at Doncaster, regarding a motor internal connection. The motor was before me and had the data plate details as well, the person said we didn't make those motor, strange old world. Several years ago I had a slight problem with an Omeron inverter, the technical guys there were just so helpful pleased to say. John |
Gary Brightman 1 | 24/07/2020 15:28:46 |
6 forum posts 8 photos | So my curiosity got the better of me and I took the thing apart to see for myself what is going on inside. I have to admit that I'm not overly impressed with the construction and quality of the machining.......what was I expecting for less than £100? The vial is held in an aluminium tube that has some form of external paint finish and this bears onto the heads of the 'adjusting' screws that appear to be fairly standard hex headed machine screws. Quite crude really! So here's a few shots of the innards..... |
Baz | 24/07/2020 17:36:17 |
1033 forum posts 2 photos | Looks crude but obviously works, cannot think of a more elegant way of doing it without costing a lot of 💰 |
