Tony Martyr | 30/06/2020 09:20:08 |
![]() 226 forum posts 45 photos | On a beam engine I built some years ago the watts govenor was driven through a coiled spring steel 'belt' that was bought as a length, cut to suit and jioned by screwing the tapered end into the cut end. I have no idea where I got this material from - can someone point me in the right direction? I am a bit concerned that such a drive using vee-groved pulleys might not be able to drive the Double tangye arrangement I have made and have seen in photos that a flat belt has been used - scarf-jointed and glued? Tony |
JasonB | 30/06/2020 09:27:17 |
![]() 25215 forum posts 3105 photos 1 articles | Stuarts do it in about 3mm dia and Mamod spring belts are about 1.5mm dia |
Nick Clarke 3 | 30/06/2020 09:30:01 |
![]() 1607 forum posts 69 photos | It used to be a standard item used for film projectors in the 1960's but as they have gone so I suspect has the spring belting from that source. |
not done it yet | 30/06/2020 12:18:07 |
7517 forum posts 20 photos | Have nothing to suggest except ask if these are the same as, or similar to, the springs use in oil seals? |
R Johns | 30/06/2020 13:21:13 |
42 forum posts | Mamod do closed and open ended steel spring belts. |
Tony Martyr | 01/07/2020 09:17:21 |
![]() 226 forum posts 45 photos | Thanks to all - I have now found what I needed from Mamod spares |
