Inverter to run Qualter and smith power hacksaw
Which inverter or motor package
Lee Kennedy16/06/2020 11:13:00
17 forum posts
5 photos
Morning all,
I have a power hacksaw I haven’t used for some time due to no longer having 3 phase power.
can I run this motor from an Inverter or is a motor inverter package the best option??
thanks
not done it yet16/06/2020 11:20:56
7517 forum posts
20 photos
Have you checked on the rating plate to see whether it is wired as a dual voltage motor?
The answer is more probably yes, but may need modifying.
Lee Kennedy16/06/2020 12:04:01
17 forum posts
5 photos
I did try to attach a picture of plate. I will try again at home.
the plate says 380/440v not 240/415.
Simon Williams 316/06/2020 15:58:35
728 forum posts
90 photos
....and check the speed, as I have a hazy recollection that the one I used to have had a 6 pole motor on it. So if you wanted to swap the motor it would dance like a thing possessed running with a four pole motor.
Though it's possible I've got muddled between this and a Wicksteed saw I also had back in the mists of time. The motor plate will tell you what the nominal full load speed is.
HTH Simon
Lee Kennedy16/06/2020 17:44:48
17 forum posts
5 photos
Simon,
original motor is 950rpm.
i have found a single phase motor 900 rpm. I will hopefully go with this.
thanks
