Chinese DRO’s
Help|
JES01/06/2020 15:25:59
84 forum posts
71 photos
I have just got a set of two linear scales and a display unit. Has anybody any expertise on this set up. I have powered on the display with one of the scales connected but I can get absolutely no movement of the display when the linear scale is moved. This is the same on both channels with either of the scales connected.
During the setup it asks for the baud rate to be set, I didn’t think his would be relevant with a ttl input?
I have contacted the vendor but as yet I have had no reply.
Any Experts out there?
Paul Lousick01/06/2020 23:39:29
2276 forum posts
801 photos
There are lots of DRO's. More details about the scales would help. Make and model, photo, etc.
Paul
JES02/06/2020 08:41:05
84 forum posts
71 photos
Thanks for the reply Paul I will attempt to take some Photos today.
JES02/06/2020 13:25:57
84 forum posts
71 photos
img_20200602_140208.jpgimg_20200602_140119.jpgimg_20200602_100418.jpgI have taken 4 Photos but There does not seem to be much information
Thanks for any thoughts on the problem.
jes
John Rutzen02/06/2020 13:40:28
411 forum posts
22 photos
I've got one this year and no problems. I did not have to set anything up, it just worked out of the box. I did however get the scales [jing- same as yours] and the display from the same supplier on Banggood. Could be yours aren't compatible.
JES02/06/2020 14:01:33
84 forum posts
71 photos
I think you may be right, I will have to try to return the unit for a refund.
Many thanks
jes
Dave Halford02/06/2020 18:14:23
2536 forum posts
24 photos
Jes,
You should have had the book, tell him through Ebay it's an incomplete order.
link
This is a sino set up sino srt up
resolution 0.005mm or 0.0001mm
Edited By Neil Wyatt on 03/06/2020 11:46:45
Martin Connelly02/06/2020 18:34:01
2549 forum posts
235 photos
They are possibly not safe since they have the Chinese Export C E rather than the correct European version.
Martin C
Mike Henderson 102/06/2020 23:27:27
29 forum posts
I have a friend who is renowned for seeking the keenest price. He bought a readout and scales direct from China but separate suppliers.
Physically compatible but the plnouts on the scales were different to those required by the readout, even though the plugs fitted. He persevered. Rewired the plugs and got it all working.
Given the separate suppliers, he hardly had grounds to reject either. Me, I'd rather get the whole setup from the same supplier even at a somewhat higher cost.
Not saying this applies to the OP, just something else to be aware of.
