Heat Bed Thermistor
Enough!26/05/2020 16:25:52
1719 forum posts
The typical heat bed thermistor .... does its resistance increase or decrease with rising temperature?
I'm assuming it decreases but I would like to get it confirmed.
Neil Wyatt26/05/2020 17:07:11
19226 forum posts
749 photos
86 articles
Yes, I'm pretty sure the standard is an ntc thermistor. Also used for the extruder.
They are surprisingly accurate.
Enough!26/05/2020 17:17:14
1719 forum posts
Thanks, Neil (not Niel as I'm sure you know wink ).
So a temperature display that flickers from 60 °C to 7000-odd °C is indicating an intermittent short rather than open circuit.
duncan webster26/05/2020 22:07:46
5307 forum posts
83 photos
depends how it is wired into the circuit and what is measured. If it is connected Vcc-thermistor-fixed resistor-ground then as the tem goes up, the thermistor resitance goes down so the voltage at the thermistor-resistor joint goes up, and if te thermistor goes open circuit the voltage goes to zero.
However if it is the other way up, the voltage at the joint goes down with increasing temperature and goes to Vcc if the thermistor is open circuit
Enough!26/05/2020 22:31:37
1719 forum posts
Certainly ohm-meter measurements, with the thermistor plug disconnected at the PCB, indicate an intermittent open-circuit. Moreover that's the failure mode I'd expect from a constantly flexing cable. There's no visual sign of any short.
So I think your explanation has it, Duncan - thanks.
Edited By Bandersnatch on 26/05/2020 22:31:52
