Emco servo conversion - compact 5 cnc
sam sokolik20/05/2020 17:10:07
126 forum posts
I finally got back to the Emco project after a few years. Squirrel! I had thrown it together trying out some pwm drives I had - which seem to work great. When I started pllaying with the spindle I started getting noise. (sporadic estop pulses). (mainly because in my excitement of the servos working well - I didn't pay much attention to grounds..)
So - Taking the time to do it right.. (I want a little lathe to test the polygon turning..)
Currently the servos are tuned with a max following error of .00007", acceleration of 40in/sec^2 and top speed of 150ipm. Very happy with this - and it looks like I could up the acceleration.
Old steppers on the right - 72steps/rev - non hybrid.
sam sokolik21/05/2020 03:34:26
126 forum posts
addendum... There was a setting in the ini file that was capping the acceleration at 6in/sec^2.. No wonder why it looked so good. So - upping the acceleration to 50in/s^2 I get a peak following error of .0002" (10 encoder counts - which is exactly what I would expect) Now it feels as expected - accelerating to 150ipm is pretty instant.
sam
Manofkent21/05/2020 07:26:57
145 forum posts
29 photos
Hi
I presume you are using service motors fitted with encodes?
What encoder interface have you used?
sam sokolik21/05/2020 15:25:21
126 forum posts
Posted by John Hilton on 21/05/2020 07:26:57:
Hi
Yes - some Pitmann servos that came with 500 line encoders. I am using Mesa interface hardware that does the high speed pwm and encoder counting. (5i25) which acts like 2 super high speed printer ports. (expandable - you can get daughter boards that do all kinds of cool stuff - analog servos, steppers and such)
I am using it in kinda unconventional way (think cheap a$$) (mesa + cheap bob)
sam sokolik24/05/2020 14:16:40
126 forum posts
A bit of an update
sam sokolik01/06/2020 21:10:53
126 forum posts
some machining required...
sam sokolik07/06/2020 21:49:07
126 forum posts
Getting there
sam sokolik13/07/2020 05:12:15
126 forum posts
I Thought I would show an update..
sam sokolik13/07/2020 05:15:32
126 forum posts
Former Member13/07/2020 08:11:56
Dave Smith 1413/07/2020 08:48:08
222 forum posts
48 photos
Great result, but please keep your fingers away from the moving parts even a small machine will take a finger off.
Joseph Noci 113/07/2020 14:54:33
1323 forum posts
1431 photos
Still nine fingers left then though...
Sam, what CAD/CAM software did you use to generate the cut file? Is the cut file G_Code?
I wonder how practical some live tooling would be on a setup like that? A third axis in Z bolting in place of the tool post with an ER spindle - would make the bolt head a lot easier on the machine!
Very nice setup - servos are certainly well tuned!
Nice job!
Joe
sam sokolik13/07/2020 15:05:55
126 forum posts
Posted by Dave Smith 14 on 13/07/2020 08:48:08:
Agreed - I was unprepared for the first run of the program.
sam sokolik17/07/2020 04:20:54
126 forum posts
more close up action...
Joseph Noci 117/07/2020 08:10:38
1323 forum posts
1431 photos
sam sokolik17/07/2020 16:09:54
126 forum posts
That was all by hand gcode. The actual polygon turning is currently done by sending info to hal layer from gcode.. I hope to do a remap but I am not there yet. So something like (this is on the mill - polygon boring)
(polygon radius)
m68e0q.30625
(number of sides)
m68e1q6
(Cutter diameter - probably get from the tool table in the future)
m68e2q.375
(rotate poly 0deg)
m68e3q0
(enable polygon component)
m64p0
(disable polygon component)
m65p0
