What size bore for correct fit?
Nick Clarke 3 | 14/05/2020 10:25:46 |
![]() 1607 forum posts 69 photos | I need to fit some oilite type bushes into steel. They are 3/4" bore 7/8" od finished. At present, unfitted, the od is 0.880" I know they will compress down to the 3/4" bore when fitted - but what size should the steel be bored to do this? Thanks Nick |
Keith Long | 14/05/2020 10:37:05 |
883 forum posts 11 photos | Nick a 5 second search on the internet came up with this link from the makers themselves.
Phil P | 14/05/2020 10:45:57 |
851 forum posts 206 photos | At work we always use a reamed (H7) hole for Oilite bushes. Phil |
Nick Clarke 3 | 14/05/2020 10:51:28 |
![]() 1607 forum posts 69 photos | Thanks guys - Keith - I bought my bushes a few months back from a local bearing supplier, but I had seen the Bowman page - Unfortunately I can't see fitting tolerances on there - hence my enquiry. Keith - so a 7/8" reamed hole will squeeze the bush to size? - I want to run precision ground stock in the bush so finished size is important to me. Thanks again, Nick
Edited By Nick Clarke 3 on 14/05/2020 10:56:37 |
Michael Gilligan | 14/05/2020 11:04:13 |
![]() 23121 forum posts 1360 photos | Nick, Have a look at this previous thread: **LINK** https://www.model-engineer.co.uk/forums/postings.asp?th=124276 MichaelG. ________ [quote] It's rather buried in the Bowman site, so this direct link might be useful: http://www.bowman.co.uk/products/oilite_bearing_calculator?measure=metric&type=plain [There is a companion one for flanged bearings.] Choose an appropriate size for the bearing and then look at all three tabs. [/quote] . Edited By Michael Gilligan on 14/05/2020 11:07:33 |
Hopper | 14/05/2020 11:30:50 |
![]() 7881 forum posts 397 photos | You can ream the bushing to final size if needed. Oilite literature says use a sharp reamer. |
Nick Clarke 3 | 14/05/2020 11:47:01 |
![]() 1607 forum posts 69 photos | I think I can see what the problem is. The Bowman site give information on the housing dimensions etc for metric bearings and not for imperial sizes - or at least not for this particular imperial size. Entering 0.750 bore, 0.875 od and 1" length and imperial standards into the bearing finder produces a bearing, but not the fitting information that you get if you use metric sizes and the UK standard. So when you guys were saying it is on the Bowman site you were quite correct - but not for this size! And when I was saying 'Oh No it isn't' I was correct too! Isn't the internet a wonderful thing. Thanks everyone for your efforts Nick
John Paton 1 | 14/05/2020 12:13:44 |
![]() 327 forum posts 20 photos | Hi Nick, Just checking that you also know not to lubricate, drill or ream the Oilite without careful reference to makers instructions? (it is very easy to clog / 'smear' the surface and prevent the lubricant coming through) I learned the hard way some years back! |
Phil P | 14/05/2020 12:15:54 |
851 forum posts 206 photos | Hello again. I have just dug out my works copy of the Oilite data sheet. Your bush being 7/8 OD x 3/4 ID is a CT.15 by the looks of it, they come in various lengths from 1/2" to 1 1/4" The actual ID high limit is 0.7515" The actual OD low limit is 0.8765" The bearing conforms to BS4480 and ISO 2795 and is suitable for fitting into a housing made to H7 limits, providing the housing is rigid the resultant fitted bore will be H7. If a fitting pin is used it should be to a tolerance of m5. Hope this is what you were needing. Phil |
