Richard Cox | 07/05/2020 18:33:15 |
60 forum posts 19 photos | hi all I’m trying to learn fusion 360 which is challenging I’m watching Paul mcwhorters videoes and in lesson 6 **LINK** at 1hr 4 mins he creates a 3D fillet on a hinge when I try to do this my blue indication arrow points the wrong way and I can’t see a way on making it move horizontally along hinge plane it’s starting to frustrate me, any ideas see pic |
JasonB | 07/05/2020 18:39:01 |
![]() 25215 forum posts 3105 photos 1 articles | Does not look like your hinge parts long edge is actually against any surface so probably why it won't create a fillet as it needs an internal corner eg junction between box side and underside of hinge
EDIT, I just sketched something similar and it worked fine.
Edited By JasonB on 07/05/2020 18:52:45 |
Richard Cox | 07/05/2020 18:53:11 |
60 forum posts 19 photos | Posted by JasonB on 07/05/2020 18:39:01:
Does not look like your hinge parts long edge is actually against any surface so probably why it won't create a fillet as it needs an internal corner eg junction between box side and underside of hinge Edited By JasonB on 07/05/2020 18:44:27 thanks for the reply not sure how to correct that tbh Rich
JasonB | 07/05/2020 18:56:31 |
![]() 25215 forum posts 3105 photos 1 articles | You look to have drawn the hinge on the wrong plane, possibly clicking on the box side and sketching onto that rather than the plane, zoom out so you can select the planesticking up above the box trying to select the plane that is part obscured by the box will actually select the box side Edited By JasonB on 07/05/2020 18:59:13 |
JasonB | 07/05/2020 19:02:46 |
![]() 25215 forum posts 3105 photos 1 articles | |
Richard Cox | 07/05/2020 19:06:27 |
60 forum posts 19 photos | Posted by JasonB on 07/05/2020 18:56:31:
You look to have drawn the hinge on the wrong plane, possibly clicking on the box side and sketching onto that rather than the plane, zoom out so you can select the planesticking up above the box trying to select the plane that is part obscured by the box will actually select the box side Edited By JasonB on 07/05/2020 18:59:1 cheers Jason I haven’t a clue il just start again lol
JasonB | 07/05/2020 19:09:03 |
![]() 25215 forum posts 3105 photos 1 articles | Richard, this will open the file I drew so you can have a look at that, not what he actually did on the video but I just created something similar. |
Richard Cox | 07/05/2020 19:33:31 |
60 forum posts 19 photos | Posted by JasonB on 07/05/2020 19:09:03:
Richard, this will open the file I drew so you can have a look at that, not what he actually did on the video but I just created something similar. Thanks a lot Jason much appreciated |
Ed Duffner | 07/05/2020 20:11:21 |
863 forum posts 104 photos | Hi Richard, You can only fillet an internal corner if the two converging faces are on the same body. If the hinge is a seperate body than what it is attched to you'll only be able to fillet the edges of the hinge's body, this is why the arrow is pointing the wrong way. To fillet an internal corner you need to join the hinge and the other part, you could use Modify/Combine. Or when you extrude the sketch of the hinge profile, make sure the Operation is set to "Join" in the extrude dialogue box instead of New Body. Ed.
JasonB | 07/05/2020 20:20:06 |
![]() 25215 forum posts 3105 photos 1 articles | There is also something wrong with your hinge part, what should be a hole through the block is just a "tube" as you can see the outside of it and the block itself is also just a shell as there are no ends. I'd suggest watching Lars Christensen's videos, that guy sounds a bit unsure of what he is doing. |
Ed Duffner | 07/05/2020 20:25:01 |
863 forum posts 104 photos | Hi Jason, Richard, Yeah I just noticed Richard is using the Surface workspace tab. For solids, use the Solid workspace tab. Ed. Edited By Ed Duffner on 07/05/2020 20:43:04 |
