Another mystery object.
Very fine and very coarse threads
Ian P15/04/2020 22:06:27
2747 forum posts
123 photos
This item was in a box of oddments that came with a pantograph engraver I bought many years ago, I have never really worked out what its original purpose was, its obviously not engraving related and seems to be some sort of spindle extension.
The coarse thread is 5/8" OD, 11 tpi and the large end shaft is 1" diameter. The other end appears to be made to accept a collet as it has a taper bore (16mm at mouth down to 9.53mm over 17.5mm) and the closing nut has a 45 degree internal taper, the thread about 20.5mm dia is 40 TPI which seems to indicate it was chosen to ensure best accuracy/concentricity when closing the collet. If this was some sort of extension spindle, say for a toolpost grinder then the lack of a precision register at the coarse thread end does not make sense.
The spindle is drilled through and has a removable/adjustable backstop. Its about 11" long overall
Anyone know what this might be off?
Ian P
Martin Connelly16/04/2020 00:02:14
2549 forum posts
235 photos
The 5/8" x 11 thread is found on the bottom of theodolites. May be something for mounting one on something other than a tripod.
Martin C
C T19/04/2020 11:15:33
74 forum posts
It could be an internal grinding arbour.
CT
Ian P19/04/2020 19:41:09
2747 forum posts
123 photos
Grinding spindle extension is my best guess too, the only thing that makes me curious is how it is meant to accurately locate itself and run run true.
Unlike a lathe chuck there is no register associated with the 5/8" thread, there is only the remains of the 1" diameter face once the spanner flats are taken into account so the slightest burr on the face would throw the far end of the extension quite a long way off. If it is for internal grinding then presumably it would be rotating at high rpm so concentricity and balance are really important.
The extremely fine pitch and the very close fitting thread of the collet nut point to it being a precision made item but its at odds with the mounting thread.
Ian P
C T21/04/2020 10:04:06
74 forum posts
Posted by Ian P on 19/04/2020 19:41:09:
Ian P
Ian,
I should have read your first post fully as you had already dismissed the grinding quill theory sorry,
A three things come to mind firstly do you know where the engraver came from (the company and what they produced) this may give a clue.
Secondly is it an ejector rod? The reason I ask this is because many years ago one of the things we made for the foundry industry were ejector plates and ejectors they were of a similar design to your mystery object. We never made anything as long as your one but that's not to say no one did.
It has all the features securely bolted to a plate, a number can be used of differing lengths, replaceable wear part "the ejector pin" held securely by a collet system and adjustable to ensure accurate contact with the part being ejected.
Third but the collet doesn't fit the criteria is a Core drill spindle--https://www.ebay.com/itm/2x-Core-Drill-Bit-Adapter-5-8-11-Thread-Male-to-1-2-Shank-Diamond-Power-Drill-/401074587031
CT
Edited By C T on 21/04/2020 10:04:40
