John Brown 18 | 14/04/2020 15:40:46 |
7 forum posts | Is there a relationship between dovetail cutter diameters and cutting length? Most advertised cutters don't seem to specify the cutting length, Stuart Brown |
John Haine | 14/04/2020 15:55:51 |
5563 forum posts 322 photos | What do you mean by "cutting length"? Looking at e.g. the Arc ones they define a depth of cut, I guess the assumption is that you leave a very small witness of the uncut surface. |
John Brown 18 | 14/04/2020 16:13:08 |
7 forum posts | Thank you, John. Viewed from the side the cutter is a right angled triangle and by cutting length I mean the vertical side of the triangle. I need a cutter which will give me 7.5mm on this vertical side. Arc cutters don't seem to have this depth but other advertisers don't specify it. I really am a beginner. What is a "very small witness"? |
John Haine | 14/04/2020 17:27:21 |
5563 forum posts 322 photos | Ok, simple trigonometry says that the base of your right angled triangle will be 7.5 tan 30 which is 4.33 mm. So you need a cutter capable of at least this depth of cut. |
John Haine | 14/04/2020 17:28:56 |
5563 forum posts 322 photos | Small witness would be a tiny bit of the vertical surface left. |
Howard Lewis | 14/04/2020 19:29:35 |
7227 forum posts 21 photos | John Brown 18. 4.33 mm is the depth, after the final depth of cut Just in case there is any confusion, it is like eating an elephant, one bite at a time, not all in one!, So think in terms of several passes, taking a little at a time. Howard |
John Brown 18 | 15/04/2020 13:50:42 |
7 forum posts | Thanks to both. Much appreciated. The trigonometry is the obvious (with hindsight) answer to my question. I'm off to join the village idiots union. |
Gary Wooding | 15/04/2020 13:57:30 |
1074 forum posts 290 photos | John, can you supply a dimensioned sketch of the profile of the dovetail you want to cut? |
