Member postings for John Brown 18
Here is a list of all the postings John Brown 18 has made in our forums. Click on a thread name to jump to the thread.
Thread: 13G?
15/06/2022 17:54:06
I have a thread gauge whose Whitworth section has a thread designated 13G. What is this? I can't find any reference to it in tables of Whitworth gauge.
Thread: Dovetail cutting length
15/04/2020 13:50:42
Thanks to both. Much appreciated. The trigonometry is the obvious (with hindsight) answer to my question. I'm off to join the village idiots union.
14/04/2020 16:13:08
Thank you, John. Viewed from the side the cutter is a right angled triangle and by cutting length I mean the vertical side of the triangle. I need a cutter which will give me 7.5mm on this vertical side. Arc cutters don't seem to have this depth but other advertisers don't specify it. I really am a beginner. What is a "very small witness"?
14/04/2020 15:40:46
Is there a relationship between dovetail cutter diameters and cutting length? Most advertised cutters don't seem to specify the cutting length, Stuart Brown
Thread: releasing tapers
11/02/2019 10:05:08
Many thanks to all of you who have replied. Much appreciated and will certainly allow me to proceed. Daresay I will be back with more.
10/02/2019 21:54:00
A complete beginner, I have purchased a Warco WM250 lathe. I am nervous about inserting the tapers in the tailstock (MT2) and headstock MT3 in case I can't get them out again. The tailstock taper is supposed to be self releasing which, I guess, means that if I wind the arbor right in it will pop out. Can you confirm this? Is it OK to release the headstock taper by threading a drift into the open end of the headstock and whacking it with a rubber hammer? I have bought a drill chuck for the tailstock but it is visibly shorter than the supplied MT2 centre. It is threaded M10. Could I simple lengthen it with threaded rod to reach a length suitable for the self eject to work?
Thread: Hello from Lazarus
21/12/2017 14:39:17
I,m well on in years but contemplating working in metal. My background is in biology so very different from the world of lathes and mills. I would like to obtain both of the latter but wonder if I will get enough use before the Grim Reaper appears. Nonetheless I do have a question right away. I need to gauge some screw threads and note that guages can be bought for about £5 or about £50. Is the difference important? Which gauges should I get?
