geoff adams | 26/03/2020 16:41:54 |
214 forum posts 207 photos | has anyone tried these for aluminium get a pack of 10 rods £13.00 thought i would give it a try all you need is a plumbers torch tried it today with 2 mm thick alloy sheet with a bit of practice it works well i turned a bit of 6 mm alloy under size built it up and turned it to 6 mm and threaded with great results i was a bit sceptical but it does work well Geoff |
clogs | 26/03/2020 16:50:00 |
630 forum posts 12 photos | woz it a proper firms rods n flux or off the bay of Fleas....????? ta |
Samsaranda | 26/03/2020 16:52:09 |
![]() 1688 forum posts 16 photos | I got some of EBay, yet to try it but have seen it demonstrated at shows and it works well. |
Baz | 26/03/2020 16:53:11 |
1033 forum posts 2 photos | Picked some up at Harrogate show quite a few years back and eventually used them on an ally Sweet Pea saddle casting, the bloke at the foundry had been far too enthusiastic fettling them and ground away all the machining allowance, managed to build the casting back up to where it should have been and it machined beautifully, which reminds me, I really must get and finish it, only saddle tank,cab and plumbing to go! Oh nearly forgot, painting as well. |
geoff adams | 26/03/2020 17:00:49 |
214 forum posts 207 photos | came from oxford welding supplies ltd uk |
