David K | 17/03/2020 17:16:03 |
258 forum posts 259 photos | I need to make some unions like the ones pictured below. They are for 1/8 copper pipe and I would like a neat join with minimal solder showing. I was thinking whether to use solder paste in a syringe rather than the rod which I am used too . |
JasonB | 17/03/2020 17:20:04 |
![]() 25215 forum posts 3105 photos 1 articles | If you cover the areas where you don't want the solder to flow with a resist such as Tippex then you can solder with rod or paste. |
Keith Hale | 17/03/2020 17:58:57 |
![]() 334 forum posts 1 photos | Hi David, Make a solder ring to fit inside the fitting. Probably using 1.0mm wire Flux the joint. Heat the joint line, the alloy will melt and flow towards the heat. If using paste, put it inside the fitting and heat as above. If using paste, you will probably need twice the amount you think! A ring is the cheapest option. Regards Keith |
David K | 17/03/2020 18:02:20 |
258 forum posts 259 photos | Correction fluid Tippex ? do you use this to stop the flux spreading around the joint. |
JasonB | 17/03/2020 18:18:31 |
![]() 25215 forum posts 3105 photos 1 articles | Yes and Yes. Needs to be solvent based tippex. |
David K | 18/03/2020 13:31:36 |
258 forum posts 259 photos | Thanks Jason .
Cup Alloys , had an interesting read on your site and could do with some silver solder. Would the low temp 455 be ok for this job , thanks |
Keith Hale | 18/03/2020 21:18:50 |
![]() 334 forum posts 1 photos | Hi David, 455 would be fine. It produces small neat joints. Regards Keith |
