Wilding's Small Tower Clock
gerry madden15/03/2020 20:16:06
331 forum posts
156 photos
Hi Clockmakers,
I have embarked on the above to keep me busy while the world goes into lockdown. Right now I'm drawing it all up so I can see properly how it all fits together. I plan to make a few "upgrades" (time will be the judge of that!) but there's also a few things that I don't quite understand. For example:-
1) On the pallet arbor there is no bearing bush on the pendulum end. The shaft runs directly in the apron. If it's because there is little load on this shaft, he could have done this at the other end but he didnt. What am I missing ? (I think I might try PTFE here anyway.)…..ahhhh as I write its just occurred to me that this might be his way of being able to adjust the end-float for the shaft.
2) The crutch assembly comprises of a fulcrum block and an arm. There are beat adjusting screws on the arm which move the fulcrum block. Then on the fulcrum block there are adjustable crutch pins to take out the play. My simplistic thinking is that the two parts (arm and fulcrum) could be one, with the beat adjusting screws made to do both beat and rod clearance adjustments. Again, what might I be not seeing ?
3) Instead of wood, I thought I might use good old Tufnol for the barrel. Any negatives, apart from cost ?
Gerry
Michael Gilligan15/03/2020 20:28:47
23121 forum posts
1360 photos
Forgive me asking, Gerry ...
Would that be Wilding's small Tower Clock ?
David Noble15/03/2020 20:28:54
402 forum posts
37 photos
Hello Gerry,
This clock really tempted me before I settled on the one I'm making at the moment. So I will be following your progress with interest.
David
lfoggy15/03/2020 21:55:48
231 forum posts
5 photos
John Wildings tower clock is on my 'to do' list as well. Can't answer your questions but good luck with the build.
gerry madden16/03/2020 00:39:23
331 forum posts
156 photos
Ahhh yes Michael. I was wondering how long it would take for the deliberate error to be spotted ! I think I must have been mixing things with 'John Wild', the clock man in Sheffield. ...Damn corona.. playing havoc with the brain cells...
gerry madden16/03/2020 00:42:57
331 forum posts
156 photos
Can the moderators correct the title so as we don't confuse people for the next ten thousand years ?
