Chris123 | 04/03/2020 20:47:06 |
123 forum posts | Evening, I need to slot a large quantity of HDPE with a slot drill / endmill. Im wondering if the low helix cutters for aluminium would be better? Thanks. Edited By Chris123 on 04/03/2020 20:50:39 |
Nick Hulme | 04/03/2020 21:24:24 |
750 forum posts 37 photos | YG Alu Power are good in plastics.
Ian P | 04/03/2020 21:53:54 |
![]() 2747 forum posts 123 photos | By coincidence I was sent a link today for some cutters that look to be ideal for your purpose. You should be able to Google this 'ALU XP Europa Tool'
Ian P |
Chris123 | 08/03/2020 14:36:00 |
123 forum posts | Thanks, I will look into the suggestions. |
Joseph Noci 1 | 08/03/2020 16:10:54 |
1323 forum posts 1431 photos | I have had quite good results with 2 flute fine grain carbide endmills - these intended for straight plunge into the material. The one flute is larger than the other, ie, the flutes are not symmetrical around the axis of the cutter, so the end of the cutter does not have a 'dead' center and cuts fully as it plunges. I will take a photo of the cutter and post for you tomorrow. 4 Flutes worked poorly - insufficient room as the swarf expands, is trapped and heats up rapidly.
I used a cutter 12mm diameter, flutes 80mm tall. The flute makes a spiral almost 2 times in the 80mm length. It was used to rough route composite wing molds in HDPE, depth at max was 25mm @ 140mm/s feed, cutter RPM = 3800. I found feeds less than 20mm/s left very poor side wall finish , I suppose due to rubbing rather than cutting.
Joe |
Ketan Swali | 08/03/2020 16:48:23 |
1481 forum posts 149 photos | Consider this link or the longer ones in the same type. I think you meant to say high helix. They are two flute, uncoated and plunge type as described by Joseph. Ketan at ARC |
old mart | 09/03/2020 19:35:23 |
4655 forum posts 304 photos | I would also go for a solid carbide for aluminium, the uncoated type. How the plastic will cut using the parameters you are confined to remains to be seen, good luck. |
