Reamers
Alan Gordon 428/02/2020 16:30:51
129 forum posts
13 photos
Hello everyone, I am looking for advice where I might purchase good quality parallel fluted reamers.
roy entwistle28/02/2020 16:38:44
1716 forum posts
It might help if we knew where you live. I find Tracey Tools OK for things like that
Roy
Howard Lewis28/02/2020 16:39:47
7227 forum posts
21 photos
Parallel flute reamers tend to be more prone to chatter in my experience. Helical fluted ones are superior, if only because the location in the bore is better.
If you are talking diameters, Hand reamers taper for a greater length than Machine reamers which have only a short lead.
My preference when holding in the Tailstock is to use a holder which allows the reamer to float. This allows the reamer to follow the hole, and lessens the risk of the Reamer acting as a boring bar to cut oversize.
Andrew Johnston28/02/2020 16:40:14
7061 forum posts
719 photos
I buy from Drill Service in Horley.
Nigel McBurney 128/02/2020 17:03:49
1101 forum posts
Alan I think that you mean ,"machine reamers," these have minimum lead and produce parallel holes nearly down to the bottom of blind holes, the flutes are usually spiral which helps produce truly round holes. The company where I worked used Drill Services at Horley Surrey over 30 years ago. Their products were very good and as Andrew ueses them now they must still be good,their products were never cheap but were very good, I have a lot of machine reamers some purchased others "won" they are far more useful than hand reamers and if treated with care,run at half drilling speed and properly luricated they will last for years.
Tony Pratt 128/02/2020 17:48:50
2319 forum posts
13 photos
I use Drill Services also.
Tony
Alan Gordon 429/02/2020 08:15:10
129 forum posts
13 photos
Thanks Chaps, Good advice which I will take,
Edited By Alan Gordon 4 on 29/02/2020 08:18:12
